Please help me figure out the flaw in my logic
Results 1 to 3 of 3
    Default Please help me figure out the flaw in my logic
    I'm trying to make a tap tempo for an echo sound effect. The delay time (length of time between echoes) is set by a digital potentiometer. The user interfaces with the PIC either by an actual analog potentiometer (using the ADC of the PIC16F676) or by tap tempo. Tap tempo is when you press a button to tap out the beat of how fast or slow you want the echoes to occur.
    The PIC checks to see first if the analog potentiometer has been moved. If the analog pot has been moved, then it moves the digital pot to mimic the analog pot. If it hasn't been moved, it waits for a button press.
    If the button has been pressed, it then begins counting the time between the first button press and the second. When it detects the second button press, it moves the digital potentiometer according to how much time has elapsed between the two button presses. It's using the TMR0 interrupt to count, so the "ticks" variable is always counting whether or not the PIC is waiting for a second button press. The ticks variable is simply reset to zero when it receives its first button press.
    The one complicated part about this program is handling the waiting time between when the program begins running and the first button press, and the waiting time between the last time the user used the tap tempo the next time the user uses the tap tempo. I don't want the echo time to change on the first button press, only on the second button press or subsequent button presses that occur before 265 ticks have elapsed.
    I tried to handle this by making the ticks variable loop between 256 and 900 once it counts up to 900, so that when the first button press occurs, it knows that if tapcount is greater than 255, then this is the "first" tap and not the second tap.
    Everything is working perfectly except I cannot get it to reset ticks on the "first" tap. For some reason it always goes to the movedigipot1 subroutine on the first tap, so when I press the button for the first time, it changes the echo time. It works correctly on the second buttonpress and all subsequent buttonpresses, but it should not move the digipot on the first press.
    Any ideas as to what it is I'm doing wrong here?
    #config
        __CONFIG _CP_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT& _MCLRE_OFF
    #endconfig
    ADCON1 = %00000000
    ANSEL = %00000111
    CMCON = %00000111
    TRISA = %00001111
    TRISC = %00000000
    ' Set TMR0 to interrupt every 16.384 milliseconds
       OPTION_REG = $55        ' Set TMR0 configuration and enable PORTB pullups
       INTCON = $a0            ' Enable TMR0 interrupts
       On Interrupt Goto tickint
        '    Hardware connection
        ' lug 1 of pot to Vdd, lug 3 of pot to Vss
        CS          VAR PORTC.0
        SCK         VAR PORTC.1
        SDI          VAR PORTC.2
        pushbutton var PORTA.3       'tap tempo button
        buttonON var PORTC.5          'tap tempo press LED
        '    Variables definition
        x var byte
        xprevious var byte
        tapcount var byte
        ticks var byte
        '    Software/Hardware initialisation
        cs = 1      ' disable MCP
        PAUSE 100   ' safe settle time
        gosub readpot
        gosub movedigipot1
        xprevious = x
        buttonON = 0
        tapcount = ticks
        gosub readpot
        xprevious = x
        pause 10
        if pushbutton = 0 then
            goto tappress
        gosub readpot
        if xprevious != x then                           'check to see if potentiometer has moved.  If it has moved...
            gosub movedigipot1                          'change delay time
        pause 10
        if tapcount > 900 then                      'prevent tapcount/ticks variables from becoming too big while waiting for buttonpress
            ticks = 256                            '256 is maximum number of ticks between taps before resetting
    tappress:
        if tapcount > 255 then                    'if more then 255 ticks have elapsed since last tap....
            ticks = 0                             '.....clear oddtap and return to main
            gosub debounce
            x = tapcount
            gosub movedigipot1                        'change delay time to tap tempo
            ticks = 0                                 'clear tapcount and return to main
            gosub debounce
    debounce:
    buttonON = 1
        do until pushbutton = 1
            pause 10
        loop
        buttonON = 0
    movedigipot1:                                                    ' subroutine to move 127 step MCP4232 SPI digital potentiometer
        CS=0
        shiftout SDI, SCK, 1, [010001, x + 7]                 ' move wiper A
        CS=1
    readpot:
        adcin 0,x                                       'read voltage of "delaytime" pot
        x = x/2                                         ' convert to 7 bit
    ' Interrupt routine to handle each timer tick
    Disable            ' Disable interrupts during interrupt handler
    tickint:
       ticks = ticks + 1         ' Count 1/60 of second on every interrupt
    tiexit:
       INTCON.2 = 0    ' Reset timer interrupt flag
       Resume
    Default Re: Please help me figure out the flaw in my logic
    For starters, IF tapcount > 900 is never going to be true and ticks = 256 will result in ticks being set to 0 since both tapcount and ticks are declared as BYTEs.
    DUH!!!!!
    Thanks, Henrik! I knew it had to be something obvious that I was overlooking. Changed those to word and it works flawlessly now!
  1. How to Figure Out Compile Errors?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 25th February 2013, 19:54
  2. Replies: 2
    Last Post: - 8th April 2012, 16:11
  3. Replies: 4
    Last Post: - 9th July 2011, 10:03
  4. I can not figure out an LCD issue
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 11th March 2010, 14:54
  5. More trouble - Just can't figure it out.
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 12:45
