Timer in real time
Results 1 to 8 of 8
    martarse's Avatar
    martarse Guest
    Unhappy Timer in real time
    hello,
    One of my friend ask me to post the question here:
    Marc, My friend, want to know how he can make a timer in real time (24 hours/day) to make a specific task.
    In the bottom I have paste his example code that he want to start with. Marc want to know which specific crystal and prescaler are required? and if this method is good to get a second, minutes and hours equal to a real to the real world time.
    Let us know if you are a better ways to get the result.
    Thanks!
    Martin and Marc!
    He want to make his program starting with this code example, here is the code :
    ' LCD clock program using On Interrupt
    ' Uses TMR0 and prescaler. Watchdog Timer should be
    ' set to off at program time and Nap and Sleep should not be used.
    ' Buttons may be used to set hours and minutes
    Define LCD_DREG PORTb ' Define LCD connections
    Define LCD_DBIT 4
    Define LCD_RSREG PORTb
    Define LCD_RSBIT 3
    Define LCD_EREG PORTb
    Define LCD_EBIT 0
    define LCD_BIT 4
    DEFINE LCD_LINES 1
    hour var byte ' Define hour variable
    dhour var byte ' Define display hour variable
    minute var byte ' Define minute variable
    second var byte ' Define second variable
    ticks var byte ' Define pieces of seconds variable
    update var byte ' Define variable to indicate update of LCD
    i var byte ' Debounce loop variable
    Pause 100 ' Wait for LCD to startup
    hour = 0 ' Set initial time to 00:00:00
    minute = 0
    second = 0
    ticks = 0
    update = 1 ' Force first display
    ' Set TMR0 to interrupt every 1:64 16.384 milliseconds
    OPTION_REG = $15 ' Set TMR0 configuration and 1:64
    INTCON = $a0 ' Enable TMR0 interrupts
    On Interrupt Goto tickint
    ' Main program loop - in this case, it only updates the LCD with the time
    mainloop:
    'PORTA = 0 ' PORTB lines low to read buttons
    'rtfecs*TRISA = $f0 ' Enable all buttons
    ' Check any button pressed to set time
    If PORTA.0 = 1 Then decmin
    If PORTA.1 = 1 Then incmin ' Last 2 buttons set minute
    If PORTA.2 = 1 Then dechr
    If PORTA.3 = 1 Then inchr ' First 2 buttons set hour
    ' Check for time to update screen
    chkup: If update = 1 Then
    Lcdout $fe, 1 ' Clear screen ,l
    ' Display time as hh:mm:ss
    dhour = hour ' Change hour 0 to 12
    If (hour // 12) = 0 Then
    dhour = dhour + 12
    Endif
    ' Check for AM or PM
    If hour < 12 Then
    Lcdout dec2 dhour, ":", dec2 minute, ":", dec2
    second, " AM"
    Else
    Lcdout dec2 (dhour - 12), ":", dec2 minute, ":",
    dec2 second, " PM"
    Endif
    update = 0 ' Screen updated
    Endif
    Goto mainloop ' Do it all forever
    ' Increment minutes
    incmin: minute = minute + 1
    If minute >= 60 Then
    minute = 0
    Endif
    Goto debounce
    ' Increment hours
    inchr: hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Goto debounce
    ' Decrement minutes
    decmin: minute = minute - 1
    minute = 59
    Endif
    Goto debounce
    ' Decrement hours
    dechr: hour = hour - 1
    If hour >= 24 Then
    hour = 23
    Endif
    ' Debounce and delay for 250ms
    debounce: For i = 1 to 25
    Pause 10 ' 10ms at a time so no interrupts are lost
    Next i
    update = 1 ' Set to update screen
    Goto chkup
    ' Interrupt routine to handle each timer tick
    disable ' Disable interrupts during interrupt handler
    tickint: ticks = ticks + 1 ' Count pieces of seconds
    If ticks < 61 Then tiexit ' 61 ticks per second (16.384ms per
    tick)
    ' One second elasped - update time
    ticks = 0
    second = second + 1
    If second >= 60 Then
    second = 0
    minute = minute + 1
    minute = 0
    hour = hour + 1
    If hour >= 24 Then
    hour = 0
    Endif
    Endif
    Endif
    update = 1 ' Set to update LCD
    tiexit: INTCON.2 = 0 ' Reset timer interrupt flag
    Resume
    Salut Martin
    There's a simple way to do it, but require a bit of extra hardware. An RTC, something Like DS1307. Really easy to use. That way, no need to care about the timing and blah blah blah. Just read the RTC when you want and do the according stuff.
    Feb 2004
    Germany
    I would recommend the use of an RTC
    (DS1307 or similar.)
    Search the forum for RTC*
    and you'll find many examples.
    EDIT: Steve, you have won (as usual)
    regards
    Ralph
    martarse's Avatar
    martarse Guest
    Hello,
    thanks for your reply. my friend has already analyzed the RTC solution. He wants something software that is included in a PIC also for further development, very low cost and very simple.
    anything else ?
    Do a search for the Olympic Timer thread...
    There's a bunch of other idea that spring to mind. Is the unit will be battery powered or AC powered?
    If it's AC powered, i would prefer to use the AC as timebase, use an internal timer interrupt to get the 1 Second or 1 minute. Once in the interrupt do the math and check for Alarm or Events.
    BUT you can do it with the internal Tick FOSC/4, in this case use one of the lower Crystal frequency... let's say 4 MHZ => internal = 1MHZ => ticks every 1 uSec => internal timer interrupt every 1000 counts to have a time base of 1 Sec => you need a 16 bits Timer.
    Wich PIC Marc will use ???
    Process is almost the same than with an RTC but you'll have to deal with a bunch of more code line to take care of the days of week/month/year/Leap Year/hours/minutes... BLAH BLAH BLAH, tsé veux dire !!!
    NOT impossible, a bit tricky, i agree.
    What the unit will also do?
    martarse's Avatar
    martarse Guest
    HEllo
    Marc make an automatic food system for Deer hunting. It's a little contract that ones of his neighboor ask for.
    Marc use a 16F84A-4MHz. Unit will be DC powered.
    He will get back to me soon. He actualy looking at some tricks mentionned here.
    I Will let you know how is going with his tests.
    thanks again!
    Martin et Marc
  1. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 05:52
  2. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 17:05
  3. Real time the right way?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 19:38
  4. Real time clock... what a headache!
    Last Post: - 8th June 2006, 22:56
  5. please read it ( real time)
    By moud_man in forum mel PIC BASIC Pro
    Last Post: - 20th September 2005, 15:38
