Structured Array
Results 1 to 5 of 5
    Bombay, India
    Default Re: Structured Array
    How about this way?
    '  One log record
      voltage       con     0                 ' byte
      amps          CON    voltage+1      ' word (amps is 1 byte away from voltage)
      drive          CON    amps+2         ' word (drive is 2 bytes away from amps)
      climit          con    drive+2          ' word
      stat           con     climit+2         ' byte
      szLog         con     stat+1
    DataLog         var     byte[szLog]   ' reserve the bytes for structure
    This takes care of your struct size and also its member offsets - akin to doing it in assembler. This is similar to what you have suggested.
    Well it works. I previously had 5 arrays now everything is in one nice contiguous block ready to send to the data logger. if nothing else the code [excluding the user command bits] looks simpler and more readable.
    using the
    ' One log record
    szLog con stat+1
    method and ext var declarations is fine up until you need to have a mixed array with bytes and word vars and more than One log record that you can step through to read and write in a loop.
    my method works fine but I think its only cosmetically better than in this case using 5 separate arrays.
    anyway its been good practice with macros and user command
    here is the demo code if your interested on a 16f1825
    printout
    ready v2
    fetched a word 5139
    fetched a byte 24
    fetched put word 1234
    fetched put byte 56
    array byte to any byte 8
    array word to any word 3083
    any array byte to any byte 44
    any array word to any word 11308
    array variable byte to any byte 8
    array variable word to any word 3083
    any array variable byte to any byte 44
    any array variable word to any word 11308
    Battery V A PWM
    0 0 0201 0403
    1 8 0A09 0C0B
    2 16 1211 04D2
    3 56 1A19 1C1B
    4 32 2221 2423
    5 40 2A29 2C2B
    6 48 3231 3433
    7 56 3A39 3C3B
    8 64 4241 4443
    9 72 4A49 4C4B
  1. Copying Array to Array
    By vamtbrider in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 02:12
  2. Array and IF - THEN
    By Gusse in forum mel PIC BASIC Pro
    Last Post: - 25th February 2010, 13:52
  3. Custom array of ports using array?
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 18th June 2006, 02:43
  4. Array
    By ripmax in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 23:21
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 16:43
