generally
machined pin IC sockets are used in high reliability applications, I use them in my solar trackers successfully . none have failed yet [touching wood he says]
generally
I agree with Richard but they are much more expensive.machined pin IC sockets are used in high reliability applications, I use them in my solar trackers successfully . none have failed yet [touching wood he says]
If the project has moved from prototype to final version, it's best to solder the mcu and use programming pins to update firmware when needed.
