Please look over my code
Results 1 to 11 of 11
    Mar 2004
    Default Please look over my code
    I'm using a 12F675 with 4mhz ceramic osc to control my homebuilt gate opener. I'm activating it with a wireless digital remote unit that has it's own relay, when signal is rx'd the relay simply closes and provides a high (+5v) to GPIO.3. This pin is also held low via a 10k resistor. This then toggles GPIO.0 which I have 2 status LED's hooked cathode to cathode.
    The problem is, all will work fine for days then suddenly it will start "toggling". That is, the gate will open, stop for a while then close over and over then simply go back to normal. Very randomly ! My PS is simply a sealed lead acid 12V battery with nothing else connected as of now. I thought the problem might be RF activating the wireless relay so i put a 3 second routine in, same problem so I disconnected the remote completely from the circuit and it happened again today. I currently have the board on my workbench powered by the same battery and it's stable for now, of course.
    So if you will please look at my code and see if it's something in there ? I know I'm still not real good at PBP but I've actually had a lot of success with many other projects using PBP and I love it.
    Thanks very much for your time,
    Sam
    '*  Name    : This is the one used for the gate opener !!!      *
    '*  Author  : SD                                                *
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 3/15/2016                                         *
    '*  Notes   :  THIS WORKS MUST HOLD DOWN FOR 3 SECONDS TO TOGGLE*
    CMCON=%00000111
    ANSEL=%00000000
    @ DEVICE pic12F675, XT_OSC
    _NOCLKOUT
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_ON
    INCLUDE "modedefs.bas"
    btn var gpio.3
    LoopTime var word
    'low gpio.0
    low gpio.1
    low gpio.2
    'high gpio.3
    low gpio.4
    low gpio.5
    InputButton:
    pause 20
    if btn = 1 then Check4Button
    goto InputButton
    Check4Button:
    for LoopTime = 0 to 3000     'Set time button must be down before toggle happens. 50= 50ms, 3000= 3 sec
    pause 1
    'if btn = 0 then close               'Do not use this line for gate opener
    next LoopTime
    if btn = 1 then tgl
    goto InputButton
    tgl:
    toggle gpio.0
    if gpio.0=1 then
    gosub close
    if gpio.0=0 then
    gosub open
    goto InputButton
    open
    pause 1000       'Orange LED on
    high gpio.1
    pause 18500
    low gpio.1
    goto InputButton
    close
    pause 1000     'Blue LED on
    high gpio.2
    pause 19000
    low gpio.2
    goto InputButton
    Default Re: Please look over my code
    three things
    1. these two pieces don't have proper labels ,relying on the good nature of the compiler is probably not a good idea
    open
    high gpio.1
    pause 18500
    low gpio.1
    goto InputButton
    close
    high gpio.2
    pause 19000
    low gpio.2
    goto InputButton
    2 spaghetti code like that is very difficult to debug or follow the logic of
    3 rmw issue possibilities abound
    for what its worth try it this way .it may look more complicated but it compiles to smaller code that's more predictable imo
    ps not sure what you are doing with gpio.0 , if it is a sensor indicating gate open/closed or moving state you need to add it back in to the code
    CMCON=%00000111
    ANSEL=%00000000
    _NOCLKOUT
    trisio= %111001
    btn var gpio.3          ; assume low is active
    gate_state var byte  ; 0=closed ,1= open , 2=moving
    open_gate var gpio.1
    close_gate var gpio.2
    button_count var byte   ;counter to bebounce btn and ensure hold time
    gpio_shadow var byte     ;shadow gpio  to eliminate rmw issues
    'initialise
    open_gate  = 0
    close_gate = 0
    gate_state = 0    ;assume closed on power up
    button_count=0
    gpio_shadow=0
    mainloop:
    gosub Check4Button
    if (button_count > 30) and (gate_state.1 != 1)  then gosub move_gate
    goto mainloop
    Check4Button:
    if btn=0 then
     button_count=button_count+1   ;if button is active add to count
     button_count=0    ;reset count
    move_gate:
    pause 1000  ; not sure if this is required
    gate_state.1=1  ;gate now moving
    if  gate_state.0 = 0 then ;its closed so open the gate
        gpio_shadow=gpio_shadow | 2 ; high gpio.1   Orange LED on
        ; same as gpio_shadow.1=1  if you prefer
        gate_state.0 = 1
     else       ; close the gate
        gpio_shadow=gpio_shadow | 4      'high gpio.2 Blue LED on
        ;same as gpio_shadow.2=1      if you prefer
        gate_state.0 = 0
    gpio=gpio_shadow
    pause 18500
    gpio_shadow=gpio_shadow & !6
    ;same as gpio_shadow.1=0 : gpio_shadow.2=0 if you prefer
    gpio=gpio_shadow
    'while ! btn  ; wait for button release if needed
    'wend
    button_count=0
    gate_state.1=0
    just can't help myself
    now have flashing led gpio.0 when gate in motion
    CMCON=%00000111
    ANSEL=%00000000
    _NOCLKOUT
    trisio= %111000
    open_led var gpio.0
    RUN_COUNT VAR BYTE
    'initialise
    open_gate  = 0
    close_gate = 0
    button_count=0
    gpio_shadow=0
    open_led =0
    RUN_COUNT=0
    mainloop:
    gosub Check4Button
    if (button_count > 30) and (gate_state.1 != 1)  then gosub move_gate    ;has button been on for 3 seconds
    IF gate_state.1=1 THEN     ;is the gate in motion
    open_led =! open_led     ;flash led while gate moving
    IF   RUN_COUNT THEN    ;should the motion continue ?
    RUN_COUNT = RUN_COUNT -1
    GOSUB STOP_GATE
    goto mainloop
    Check4Button:        ; when  button_count gets to 30 (3seconds ) we act on gate
    if btn=0 then
    move_gate:
        gpio_shadow.0=1     ;WILL SET open_led =  ON
        gate_state.0 = 1
        gate_state.0 = 0    ;show closed gate  open_led =  Off
        gpio_shadow.0=0   ; WILL SET open_led = FF
    gpio=gpio_shadow   ;apply to gpio
    RUN_COUNT=185;0    ;set 18.5 second timer for movement
    STOP_GATE:
    gpio_shadow=gpio_shadow & ~6   ;kill movement
    'wend
    button_count=0  ;reset everything ready for next button press
    gate_state.1=0; NOW no moving
    Mar 2004
    WOW! Thanks for all your help and work Richard!
    I'll study it and try it out. I should have done a "block flow" for what I want to happen...
    Wait for button press (GPIO.3 is button sense input)
    Require button pressed for 3 seconds (GPIO.0 toggles) (orange and blue LEDs hooked cathode to cathode as status)
    Energize relay 1 for 18.5 seconds to open gate (GPIO.2)
    Energize relay 2 for 19 seconds to close gate (GPIO.1)
    Start over
    The movement is controlled only by timing, I have no external sensors/limit switches or encoders.
    What do these mean in your code ? (!) and (;) I've not used or seen those.
    Thanks again, going to try it on the bench this morning.
    Oct 2009
    Utah, USA
    Sam,
    the ";" simply denotes a comment. Any code after the ";" has no effect on the program other than to provide a comment anyone trying to figure out what the code is supposed to be doing.
    the "!" is used in combination with the "=" and means "not equal".
    From the PBP manual...
    NOT EQUAL TO you can use either "<>" or "!="
    so where he has
    open_led != open_led
    simply means open_led "is not equal to" open_led.
    It causes the state of "open_led" to go to the opposite state. Similar to a "Toggle" command.
    A couple of other things to consider...
    Is there any chance of moisture accumulating on your PCB that would cause it to be erratic??
    Is your power supply good and stable?
    Why do you use an external ceramic resonator when the PIC has an internal 4MHz oscillator (not that this would cause you problems but it does reduce the I/O pins you have available.)
    You might want to consider incorporating a gate open/closed sensor for positive indication of gate position.
    dwight
    Dwight
    Mar 2004
    Thanks Dwight, I've always used (') to comment out notes and have used (<>= NOT) but I do now see these in the manual, I just never noticed them before. Good to know, always learning.
    The PCB is in a gasketed weatherproof enclosure and has been totally dry
    Power supply is a brand new 12v SLA battery that has been at 12+ volts consistently during this time, I use a to220 7805 with caps
    I use the XT OSC because of timing only control and temperature differences
    I did consider limit switches or better, IR limit sensors but wanted to keep it simple as possible. But that would be more precise and reliable
    Mar 2004
    Richard,
    I loaded your code, I only had to change one thing...
    Check4Button:
    if btn=0 then 'had to change =0 to =1
    And it works great ! I like the flashing LED while the gate is moving. I'll put it back in service and see how it goes, I expect it to be fine now.
    You did a lot of work and helped me a lot and I've learned much from your work and I'll continue to refer to how you've done it for my future coding.
    You're very much appreciated ! Thanks !
    Sam
    thanks for the feedback and kind words ,but I must confess its a bit fluky I was working on replacing my roller door pgm as you posted your code . I'm also using the exact relay setup you posted in the other thread
    went from this rather vague uncommented spaghetti code written 10+ years ago
     up        VAR  gpio.1
     lm        VAR  gpio.4
     dwn       var  gpio.2
     cl        var  gpio.3
     tr        var  gpio.0
     b1 var byte
     option_reg.5=0    ' gpio 2 not tock
     option_reg.6=1     ' weak pullups  ?
     trisio = %100111      '1,2 output   rest i/p
    low up                        ; motor off
    low dwn
    if tr=1 then main
    pause 80
    if tr= 1 then main
    b1=0
    input gpio.4
    if lm=0 then
    high dwn
    b1=3
    high up
    move:
    pause 250
    b1 = b1 +1
    if cl=0 or lm=0 then still
    if b1 >100 then still         'taken too long just give up
    goto move
    still:
    low dwn
    low up
    if tr=0 then still
    pause 5000
    to this ( with plenty of comments for my future self)
    in order to make a door open indicator to feed into the auto light on off switch and the alarm system.
    it bench tests ok but its not installed yet , its not a direct replacement of the old chip might need a new pcb
    ;pic12f683
      __config  _INTOSCIO & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    ' up        VAR  gpio.1
    ' lm up     VAR  gpio.4    || cl
    ' lm down   VAR  gpio.5
    ' dwn       var  gpio.2
    ' cl        var  gpio.4   over current
    ' tr        var  gpio.3
    maxrun con 2000  ;  2000 = 100 sec
    liftoff con 500 ;  .5 sec  time to move off limit sw
    settle  con 1500;   1.5 sec   time to let door settle before checking closed state
                    ;  lets current overload signal deactivate if that stopped door
    press_threshold con 20   ; 1 sec
    long_press_threshold  con 60  ;3 sec
    CMCON0=%00000111
    ANSEL=%00000000
    wpu=48           ;pullups
    OPTION_REG.7=0   ;pullups
    trisio= %111000
    trigger var gpio.3   ; low is active from button or wireless
    door_state var byte  ; 0=closed ,1= open , 2=moving
    open_led var gpio.0   ;lit when door open , flashes when moving
    open_door var gpio.1   ;relay up
    close_door var gpio.2  ;relay down
    up_lim  VAR  gpio.4  ;   low is active    limit switches current overload is wire nor'ed to this pin too
    dn_lim  VAR  gpio.5  ;   low is active
    trigger_cnt var byte ;counter
    TR_ACT  VAR BYTE
    RUN_COUNT VAR word
    'initialise
    open_door  = 0
    close_door = 0
    TR_ACT=0
    gosub chk_door
    trigger_cnt=0
    RUN_COUNT=0
    mainloop:
        gosub Chk_trigger
        if TR_ACT and (door_state.1 != 1)  then gosub move_door    ;has button been on for 3 seconds
        IF door_state.1=1 THEN   ;is the DOOR in motion
            open_led =! open_led     ;flash led while DOOR moving ****** this violates gpio shadow and may cause rmw error
            IF(gpio&48) != 48  then  RUN_COUNT=0
                GOSUB STOP_door
            gosub chk_door  ; has door been opened or closed manually
        pause 50
    goto mainloop
    Chk_trigger:        ; after  trigger_count gets to press_threshold we act on trigger release or when long_press_threshold reached
        if trigger=0 then
          Trigger_cnt=trigger_cnt+1   ;if trigger is active add to count
          IF  trigger_cnt > long_press_threshold THEN TR_ACT= 2
            if trigger_cnt > press_threshold THEN   ;press_threshold met
                   TR_ACT= 2           ;FORCE CLOSE ACTION WITH LONG TRIGGER >3 SEC
                   TR_ACT= 1
            ELSE       ;press_threshold not met
            TR_ACT= 0
            trigger_cnt=0    ;reset count
    move_door:
        IF TR_ACT=2 THEN door_state.0 = 1 ;FORCE CLOSE ACTION
        door_state.1=1  ;door now moving
        if  door_state.0 = 0 then ;its closed so open the door
            door_state.0 = 1
         else       ; close the door
            door_state.0 = 0    ;show closed door  open_led =  Off
        TR_ACT= 0
        pause liftoff  ;get door off limit sw
        RUN_COUNT=maxrun;0    ;set timer for movement
    STOP_door:
        trigger_cnt=0  ;reset everything ready for next TRIGGER
        door_state.1=0; NOW not moving
        pause settle  ;let door settle
    chk_door:
        door_state.0 = dn_lim   ; see if its closed
        open_led =  dn_lim
        gpio_shadow = gpio
    Mar 2004
    UPDATE:
    First, thanks for posting all that additional code too Richard. I've saved your 2nd code as "Richard's Gate Controller" on my programming PC and it is running my gate.
    On to my update...
    It appears I've located the cause of the erratic operation, I use sockets for PIC's and did on this project too. It looks like it's the socket causing the problems, that is, when strange things start happening, I remove and re-seat the PIC in the socket or even just press down firmly on the PIC and it's all good again.
    I think there is some oxidation on my socket and GPIO.3 (input pin) starts loosing contact and picking up random noise.
    I need to find some type of cleaner to use (vinegar ?) to clean the socket real good then maybe use some silicone grease to keep air and any moisture from getting to them. even though it's in a sealed enclosure. Any suggestions anyone ?
    thanks
    generally
    machined pin IC sockets are used in high reliability applications, I use them in my solar trackers successfully . none have failed yet [touching wood he says]
    I agree with Richard but they are much more expensive.
    If the project has moved from prototype to final version, it's best to solder the mcu and use programming pins to update firmware when needed.
  1. avr code to code for PIC
    By JasonMcG in forum General
    Last Post: - 11th September 2014, 01:57
  2. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 03:15
  3. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
