Please look over my code
Results 1 to 11 of 11
Threaded View
  1. #2
    Default Re: Please look over my code
    three things
    1. these two pieces don't have proper labels ,relying on the good nature of the compiler is probably not a good idea
    open
    pause 1000 'Orange LED on
    high gpio.1
    pause 18500
    low gpio.1
    goto InputButton
    close
    pause 1000 'Blue LED on
    high gpio.2
    pause 19000
    low gpio.2
    goto InputButton
    2 spaghetti code like that is very difficult to debug or follow the logic of
    3 rmw issue possibilities abound
    for what its worth try it this way .it may look more complicated but it compiles to smaller code that's more predictable imo
    ps not sure what you are doing with gpio.0 , if it is a sensor indicating gate open/closed or moving state you need to add it back in to the code
    CMCON=%00000111
    ANSEL=%00000000
    @ DEVICE pic12F675, XT_OSC
    _NOCLKOUT
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_ON
    trisio= %111001
    btn var gpio.3          ; assume low is active
    gate_state var byte  ; 0=closed ,1= open , 2=moving
    open_gate var gpio.1
    close_gate var gpio.2
    button_count var byte   ;counter to bebounce btn and ensure hold time
    gpio_shadow var byte     ;shadow gpio  to eliminate rmw issues
    'initialise
    open_gate  = 0
    close_gate = 0
    gate_state = 0    ;assume closed on power up
    button_count=0
    gpio_shadow=0
    mainloop:
    gosub Check4Button
    if (button_count > 30) and (gate_state.1 != 1)  then gosub move_gate
    goto mainloop
    Check4Button:
    if btn=0 then
     button_count=button_count+1   ;if button is active add to count
     button_count=0    ;reset count
    move_gate:
    pause 1000  ; not sure if this is required
    gate_state.1=1  ;gate now moving
    if  gate_state.0 = 0 then ;its closed so open the gate
        gpio_shadow=gpio_shadow | 2 ; high gpio.1   Orange LED on
        ; same as gpio_shadow.1=1  if you prefer
        gate_state.0 = 1
     else       ; close the gate
        gpio_shadow=gpio_shadow | 4      'high gpio.2 Blue LED on
        ;same as gpio_shadow.2=1      if you prefer
        gate_state.0 = 0
    gpio=gpio_shadow
    pause 18500
    gpio_shadow=gpio_shadow & !6
    ;same as gpio_shadow.1=0 : gpio_shadow.2=0 if you prefer
    gpio=gpio_shadow
    'while ! btn  ; wait for button release if needed
    'wend
    button_count=0
    gate_state.1=0
  1. avr code to code for PIC
    By JasonMcG in forum General
    Last Post: - 11th September 2014, 01:57
  2. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 03:15
  3. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
