Going back to basics, some advice on memory storage
Results 1 to 8 of 8
    Default Re: Going back to basics, some advice on memory storage
    horses an water
    I try again this seems to have gone through to the keeper
    http://www.picbasic.co.uk/forum/showthread.php?t=20966
    arrays and the ext modifier don't exist for no reason
    data_block var byte[96]
    i var byte
    ch_max var word ext   ;accessable as ch_max[0] to ch_max[15]
    ch_on  var word ext   ;accessable as ch_on[0] to ch_on[15]
    ch_off var word ext   ;accessable as ch_off[0] to ch_off[15]
    asm
    ch_max =  data_block
    ch_on  =  data_block+32
    ch_off =  data_block+64
    endasm
    save_data:
    for i = 0 to 95
    write 8+i ,data_block[i]
    next
    read_data:
    for i = 0 to 95
    read 8+i ,data_block[i]
    next
    set_defaults:
    for i=0 to 15
    ch_max[i]= 3000
    ch_on[i}= 1800
    ch_off[i]=600
    next
    Oct 2009
    Richard, your previous posts hadn't been overlooked... I was trying to keep my explanation as simple as possible with regards to the locations in order to help explain what I was looking for, which was info on the correct way to use the DATA and EEPROM statements... which you appear to of overlooked in your reply whilst you were hell bent on being sarcastic with your
    horses an water
    I try again this seems to have gone through to the keeper"
  1. I2C storage issue
    Last Post: - 19th November 2010, 20:42
  2. Memory Overflow? Urgently need advice
    By curian88 in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 15:42
  3. data storage label
    By MINHLE in forum General
    Last Post: - 17th December 2009, 15:04
  4. internal storage space?
    By gtrplaya101 in forum mel PIC BASIC Pro
    Last Post: - 27th October 2009, 07:45
  5. The basics
    Last Post: - 22nd June 2008, 01:09
