HELP WITH SOME Nbit MATH
Results 1 to 11 of 11
Threaded View
  1. #2
    Sep 2009
    Default Re: HELP WITH SOME Nbit MATH
    Look at this:
    MATH_CMP  macro Zin, Xin    ; Compare Pvars - result in M_EQ and M_GTE bits
        MOVE?PP  Zin, REG_Z          ; Z <=> X -> STATUS(C,Z)
        MOVE?PP  Xin, REG_X
        CLRFSR                       ; clear FSR first
        L?CALL   M_CMP
        MOVE?TT  STATUS,Z, _M_EQ     ; STATUS,Z set if Z == X
        MOVE?TT  STATUS,C, _M_GTE    ; STATUS,C set if Z => X;
    If I understand Darrel's code then:
    • If Z and X are equal you have set M_EQ and M_GTE
    • If Z is greater than X, bit M_GTE is set, bit M_EQ is 0
    • If Z is less than X, M_GTE and M_EQ are 0
    EDIT:
    PBP code should look like this:
    IF M_EQ=1 AND M_GTE=1 THEN
    'Z = X
    ELSEIF M_EQ=0 AND M_GTE=1 THEN
    'Z > X
    ELSE 'M_EQ=0 AND M_GTE=0
    'Z < X
  1. some help with math
    Last Post: - 16th October 2015, 03:03
  2. Help with the math
    By Ramius in forum FAQ - Frequently Asked Questions
    Last Post: - 5th September 2014, 08:15
  3. Math help please...
    By Ioannis in forum General
    Last Post: - 20th June 2008, 11:18
  4. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  5. math help
    By houa in forum mel PIC BASIC Pro
    Last Post: - 30th January 2006, 17:58
