serout command
Results 1 to 2 of 2
Thread: serout command
    the_piculiar's Avatar
    the_piculiar Guest
    Default serout command
    i am using the following command:
    SEROUT PORTA.5, n300 ["hello",10,13]
    im sending this value to the serial port on a compter (com1)
    im then reading it via visual basic but even though i setup my program to read the com1 with no parity and 300 as the baud rate, it reads out as pure gibberish.
    i have also tried it with hyperterminal but i get the exact same problem
    anybody have any ideas how to read the data from the pic and convert to ascii?
    or am i doing something wrong with the pic itself
    btw, the pic in use is a 16f877
    tdavis80's Avatar
    tdavis80 Guest
    Smile
    are you using a level converter or hooking the comport to the pic via a resistor? Level converters are normally used and invert the signal. The PC expects it to be inverted. If you are only using a resistor, you must tell the PIC to invert the data.
  1. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  3. Advice-scrutiny for my serial controller
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 13th December 2008, 18:11
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 19:57
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
