Optocoupler question based on Fairchild H11G1
Results 1 to 7 of 7
    Default Optocoupler question based on Fairchild H11G1
    Do I need to put a diode across the terminals of this opto based on the attached configuration (I have to switch from the high side!) ? I selected this opto thinking that it comes with a diode already between emitter and collector but have been loosely advised that it is just for EMC purposes, so would like to make sure of this. Please I need some advice and thanks in advance.
    Name:  Screen Shot 2016-04-05 at 19.50.51.png
    ___________________
    WHY things get boring when they work just fine?
    Default Re: Optocoupler question based on Fairchild H11G1
    No. It is better to place the diode in the same polarity but across the relay to shunt the back emf when the relay is disabled by the opto. If you notice you are just paralleling the internal diode on the opto.
    EN82fn
    Hi Dave, thanks for your answer! Yes, I already have a diode across the relay, I forgot to draw it on the diagram.
    I am just not sure if the interval diode in the opto can resist a punch from the fly-back voltage/current from the relay or it will give way and render the opto useless after a few switching cycles. I am not experienced but hold basic knowledge about this and could not really find anything in the data sheet to give me some confidence towards removing the parallel diode from the opto.
    ___________________
    Dec 2010
    The diode you have drawn is not required. The diode across the coil you forgot to draw is the critical one. I'd also recommend you put the opto between the relay and GND rather than between the relay and +24, although it should be O.K. where it is. By the way, if you are only dealing with +24V, why use an opto to drive the relay? A far cheaper transistor or FET would easily do the job.
    Sep 2010
    Las Vegas, NV
    For what it's worth, and I'm probably wrong but, I don't think your worry about the opto is properly directed. I think the concern should be placed on the PIC. If you don't have the flyback diode on the relay the back EMF will be rectified through the opto into the PIC. The reverse diode in the opto will not dispose of the relay field collapsing only rectify it to the PIC. You stated the diode on the relay is there so IMWO the diode drawn across the opto is unnecessary.
    I would appreciate it if when the real engineers tell me I'm wrong that you do it gently.;-)
    it would be a very poor quality opto that could not provide the isolation necessary to protect a pic from a relay coil spike . as others have said the "flyback protection" diode goes across the coil .
    ps the opto's o/p transistor may not survive the kick but isolation should be maintained
  1. Question about Optocoupler H11G1
    By financecatalyst in forum Schematics
    Last Post: - 22nd September 2016, 07:16
  2. Looking for a PIC Based Terminal
    By rtsandiego in forum mel PIC BASIC
    Last Post: - 4th October 2012, 15:33
  3. pc based oscilloscope..
    By sindhukrish in forum USB
    Last Post: - 20th March 2009, 08:31
  4. PIC based SONAR
    By PICtron in forum Off Topic
    Last Post: - 3rd February 2005, 21:44
