Does anyone have ROMzap bootloader?
Results 1 to 7 of 7
    Unhappy
    Yes, dead ...
    but, see here ... may be sthg to help !!!
    http://massmind.org/techref/microchip/devprogs.htm
    Aug 2003
    That's a dead link from here as well unfortunately...
    Done! Being sent to your address.
    It was my favourite bootloader too, till I switched over to the MCSP+.
    What I found very useful is its ability to use virtually any pins for the interface, and the option to have a direct connection without a converter/inverter.
    Anand
    Question Me too please
    Could I have that bootloader too?
    Is it only for the PIC16F87x micros?
    Regards.
    ---> picnaut
    Aug 2003
    Thanx a lot Anand I reveived the file ok, installed it, and am eager to try it.
    The ability to use any pic pins was the reason I was chasing that particular bootloader.
    Picnaut, I would have sent it on to you, but you haven't included your email address in your post.
    If you send me an email to reply to, I will gladly send it.
    Bootloaders can only work with pics that have tha ability to write to their
    own program memory.. 16F876, 877, and a few others.
    Cheers, Art.
    Aug 2003
    Hmm.. have not had much luck so far.
    I can get the Windows program to connect to the bootloader,
    and the reset function does seem to work since the LEDs in my
    project go brighter while I'm holding reset, however, when I try to
    program the chip, the software either says 'received character error',
    or it goes through the motions of programming the chip, but when I read
    it back in my programmer, there is no data other than the bootloader
    written to it.
    Another issue I have found is that DEFINE LOADER_USED 1 does not
    keep PBP code out of locations 0 & 1, and the goto line at location 1
    is needed to jump past the PBP libraries to the start of PBP user code.
    Maybe this accomodates the MElabs loader somehow.
    It seems that even if I got the loader working, the program would need to
    be pure assembler to use it properly.
    Perhaps someone who is more familiar with bootloaders can shed some light??
    Cheers, Art.
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Using the Mecanique Bootloader without the DTR reset signal
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 14th September 2005, 04:39
  5. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
