i haven't the 16F1786 in microcode studio list (pbp246), what can i do?
Results 1 to 11 of 11
    Mar 2016
    Default Re: i haven't the 16F1786 in microcode studio list (pbp246), what can i do?
    hi, i hv some problem for my project
    how to do it if u want condition like this
    ( temperature from 29C to 35C, the bulb will ON that means the bulb will ON if temperature <29C until temperature = 35C
    but when temperature >35C the bulb will OFF until the temperature reach to or below 29C and that condition will repeat)
    sorry for my word, i hope someone can give a some advise or hint to help me
    thanks
    Your question is a bit contradictory.
    You say to have the bulb ON if temp is between 29-35 C.
    Then trying to explain more you say bulb ON if temp < 29 and until temp reaches 35.
    Please clarify what exactly you want.
    Oct 2009
    Quote Originally Posted by Student92 View Post
    thanks
    What exactly is your project, it sounds very much like a thermostat of some description ?
    What is the reason for choosing a 16F1786 over other PICs that are supported in the version of PBP you have ?
    So you want the light on when the temperature is between 29c and 35c, then you could try something like this.. crude but should work
    temperature var byte
    lamp var PORTA.1
    If temperature <29 or temperature >35 then low lamp
    If temperature =>29 or temperature =<35 then high lamp
  1. Microcode Studio Plus
    By Archangel in forum PBP Wish List
    Last Post: - 31st October 2013, 01:05
  2. using MicroCode Studio
    By Max_Gauss in forum mel PIC BASIC Pro
    Last Post: - 8th September 2011, 19:04
  3. Microcode studio
    By Stargazer3141 in forum General
    Last Post: - 28th January 2011, 22:49
  4. microcode studio plus
    By c_moore in forum General
    Last Post: - 26th July 2010, 10:45
  5. MicroCode Studio Plus
    By ozarkshermit in forum General
    Last Post: - 30th December 2009, 23:27
