Monitor supply voltage of chip?
Results 1 to 17 of 17
    Jan 2015
    Red face Re: Monitor supply voltage of chip?
    Thanks for all the replies! Yes the 12f683 doesn't have a FVR, so that's out the question. I think I am going to go with "LinkMtech's" idea and just use a 2.4v Zener to regulate the chips supply, then a divider onto a pin for reference.
    Thanks for your help.
    Default Re: Monitor supply voltage of chip?
    microchip has a to92 voltage detector...... different voltages and draws 1 microamp....
    http://ww1.microchip.com/downloads/e...Doc/21434g.pdf
    Sep 2009
    @robbo78
    That solution is not good for battery.
    With zener regulator current draw from battery is same in if pic is sleep mode as in run mode.
    If you use zener, then feed that voltage into analog pin, and then do ADC. This way current thru zener can be few uA instead few mA.
    I don't know how wedded you are to the PIC12F683 but PIC12f617 looks similar but with a 0.6v ref but no EEPROM (although it can self write so that needn't be a show stopper).
    PIC 12F1822 has FVRs and eveyrthing else you need.
    I recently made a low battery warning for a 12V lead acid battery using a 12F675. B+ 12V powers the PIC through a 3.3V LDO regulator.The same B+ 12V goes to the ADC pin through a 220K resistor. The ADC pin then has 47K to ground. Here's the code I used. It flashes an LED when the battery gets weak. Perhaps you can tweak the code and circuit for your application to put the PIC in low power mode.
    ANSEL = 0 'all inputs digital ADC command will convert it to analog
    CMCON = 7 'comparators off
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device
    TRISIO = %00000001 'INPUT ANA0 FOR ADC READINGS
    GPIO = 0 'ALL OUTPUTS LOW
    BATTEST VAR BYTE
    @ DEVICE MCLR_OFF, WDT_ON, BOD_ON, PWRT_ON, PROTECT_ON
    TEST:
    Clear 'CLEAR BATTEST
    ADCIN 0,BATTEST 'TEST CHARGE
    IF BATTEST <= 166 Then GoSub BLINK
    GoTo TEST
    BLINK:
    High GPIO.2
    Pause 500
    Low GPIO.2
    Pause 500
    Oh yes, thats nice. I don't understand why I didn't find that in the truly horrible Microchip selector... but of course, it's terrible.
    Jan 2015
    @robbo78
    Good idea! I have just found this part which is a bit of a "cheat", and quite cheap? - http://www.farnell.com/datasheets/1669371.pdf
    EDIT: Just realised that "amgen" already stated this
  1. How to use the HLVD module as a low voltage monitor
    By jellis00 in forum Code Examples
    Last Post: - 11th March 2013, 19:31
  2. Voltage monitor and PWM control
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 16:11
  3. Voltage monitor for car battery
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:47
  4. voltage monitor
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 17th August 2007, 09:57
  5. Help with DS2436 Voltage monitor
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 30th October 2006, 16:39
