Monitor supply voltage of chip?
Results 1 to 17 of 17
    Nov 2007
    West Covina, CA
    Default Re: Monitor supply voltage of chip?
    I think a fixed Vdd to the PIC set below the "low battery" level is your only recourse with this one.
    Then a simple voltage divider to monitor the battery level with the A/D to trigger sleep mode after that.
    If you're not sourcing much through the 12F1683, a small 2.?V zener is all you'll need for Vdd.
    Louie
    Oct 2009
    Utah, USA
    The datasheet for the 12f683 shows that it has an internal Fixed Voltage Reference that can be used to compare against the supply voltage.
    Dwight
    hi, Dwight,
    not really a reference for the 683 ...
    - Programmable on-chip voltage reference
    (CVREF) module (% of VDD)
    so, here it is not possible to reach the goal ...
    Sep 2009
    There is more than one way to to this. All you need is fixed reference voltage.
    Eg 0,6V from diode(if you can tolerate drift about 2mV/degC), some pic have built in diode for temp. monitoring, or pic fixed reference(FVR), or voltage from some blinking LED(Do battery check when LED is on).
    So you can feed fixed voltage on ADC pin, and use Vdd as reference for ADC. If Vdd is lower than ADC result are higher and reverse.
    Some pic have FVR on ADC multiplexer(or internal diode), so there is convenient way to do that, without loosing io pins.
    If you are using external fixed reference, you can use IO pin to turn on/off reference to minimize current draw.
    Oct 2009
    Utah, USA
    Hey Robbo,
    If you decide to use the internal Fixed Voltage Reference you might want to take a look at my second post in this tread... http://www.picbasic.co.uk/forum/showthread.php?t=19035
    and read this thread also... http://www.picbasic.co.uk/forum/showthread.php?t=17321
    sorry that my post about the FVR earlier was so short but I was at work.
    Dwight
    have a look at AN1072. Darrel wrote a piece about the subject.
    Sep 2009
    Heckler
    According to microchip's datasheet( http://ww1.microchip.com/downloads/e...oc/41211D_.pdf ) PIC12F683 doesn't have Fixed Voltage Reference.
  1. How to use the HLVD module as a low voltage monitor
    By jellis00 in forum Code Examples
    Last Post: - 11th March 2013, 19:31
  2. Voltage monitor and PWM control
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 16:11
  3. Voltage monitor for car battery
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 21:47
  4. voltage monitor
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 17th August 2007, 09:57
  5. Help with DS2436 Voltage monitor
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 30th October 2006, 16:39
