MCP23S17 init all outputs and to a logic 1
Results 1 to 3 of 3
    Sep 2007
    Waco, Texas
    Default MCP23S17 init all outputs and to a logic 1
    Hello to All-
    I have been trying to figure out the best and/or fastest way to initialize a MCP23S17 (SPI) to all outputs with an active low.
    I init the devices by calling this routing (Thanks to the Forum)
    INIT_OutA_2317:'MCP2317 used for A Outputs:
                 OutA_MCPReg = IOCON          'Configures the MCP23S17
                 OutA_DataOut = $20
                 GOSUB SEND_OutA_2317
                 OutA_MCPReg = IODIRA         'Configures PortA(1) All OUTPUTS
                 OutA_DataOut = $00
                 OutA_MCPReg = IODIRB         'Configures PortB(2) All OUTPUTs
                 OutA_DataOut = $00
    And the Send Out Sub:
    SEND_OutA_2317:
                 CSA = 0                 'Enable the MCP23S17
                 SSP1BUF = MCPWRT         'Command to Write to the MCP23S17
                 while !PIR1.3 : wend
                 PIR1.3=0        'Reset the flag
                 SSP1CON1.7=0        'Clear collision bit
                 SSP1BUF = OutA_MCPReg         'Register to Write the Data
                 SSP1BUF = OutA_DataOut        'Data to be sent
                 PIR1.3 = 0        'Reset the flag
                 CSA = 1                 'Disable the MCP23S17
    And the set port sub:
    SetPort_A:
                 OutA_hi=OutA.highbyte                             'Splits into hibyte
                 OutA_lo=OutA.lowbyte                              'And into low byte of the word var
                 OutA_MCPReg = OLATA                             'Sets up PORTA output
                 OutA_DataOut=OutA_lo                            'Sets up data to be pushed to the MCP23S17 as the low byte
                 gosub SEND_OutA_2317                            'Send it
                 pause 3                                        'Wait a bit
                 OutA_MCPReg = OLATB                             'Sets up PORTB output
                 OutA_DataOut=OutA_hi                            'Sets up data to be pushed to the MCP23S17 as the hi byte
    And then do a for next loop:
    for i=0 to 15 : OutA.0[i]=1 : gosub SetPort_A : next i
    Even working with a 18F6527 at 40 MHz, the thing comes up with all outputs active (active low is what I am looking to do) for a small time but fast enough to trigger all 16 outputs.
    I will try cutting some of the pauses but is there a better/faster way to do this?
    Any pointers would be helpful - as is always this forum......
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Default Re: MCP23S17 init all outputs and to a logic 1
    from data sheet
    Serial Data to Output Valid— — 450 ns
    CS Setup Time 50 nS
    a 3mS pause is way to long
    SetPort_A:
    pause 3 'Wait a bit cannot see that this is necessary or even adds any value
    if you want speed why set only 1 bit at a time when they all are going to be set anyway
    OutA=$ffff
    gosub SetPort_A
    would be 15 times faster
    Sep 2007
    Waco, Texas
    Thanks Richard!
    I get caught up thinking in terms of 8 bits that I forget that I can actually speak in words! Hah!
    I did miss the PAUSE statement and have changed it to PAUSEUS 10 and it seems happy.
    I used the OutA=$FFFF : gosub SetPort_A and it seems that it too fast for the outputs to actually toggle which is what I was driving for.
    Thanks again, good eye and quite helpful.
    - Albert Einstein
  1. Need to flip order of bits MSB to LSB re: MCP23S17
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2015, 01:42
  2. LCD init code ...safety
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 24th February 2011, 13:53
  3. init PORTD FOR 16F877A
    By coss_cat in forum General
    Last Post: - 19th June 2010, 17:16
  4. Init
    Last Post: - 21st April 2007, 01:43
  5. do i need to init the CG or DD in 4 bit lcd?
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 02:18
