Weird ADC / Math Results with 9-Bit PWM
Results 1 to 22 of 22
    Aug 2011
    Default Re: Weird ADC / Math Results with 9-Bit PWM
    If I put brackets around the dividing part will that fix it?
    That'll truncate the division, leaving you with 412/255 = 1
    You can use PBPL mode so that it uses LONGs, which should work but it'll be larger and slower if that matters. Otherwise your best bet might be to turn the equation into a lookup table.
    To be honest, I don't use PBP much, so maybe others can suggest something else.
    Thanks again tumbleweed. I can't use PBPL without moving up to a 18F chip, and the minimum # of pins is then 18 (I only need two outputs so an 8-pin chip is ideal. Also, the PCB is pretty cramped now as it is).
    But a lookup table could be tricky given the 0-255 range of the 8-bit ADC input but a PWM duty cycle range of 512. Maybe I should switch to 10-bit ADC and just divide by 2?
    Why not look at using the DIV32 command?
    EN82fn
    Aug 2011
    That's an interesting operation. Splitting the equation up into two parts for DIV32 seems to work...
    LEDBrVal = ((compVal - 0) * (MaxDuty - MinDuty))
    LEDBrVal = DIV32 (MaxADCVal - 0) + MinDuty
    Is it safe to do something like that or would you suggest making the DIV32 statement simpler so that you know it immediately follows the multiplication (I don't know what the OP's intent for the " - 0" part of the above is for)?
    Yes, The way you have it is OK. Just remenber that the result of the first multiplication before the DIV32 is to a dumby variable and it won't be usefull after the DIV32 function. It should be sized as a word.
    EN82fn
    Thanks Dave and tumbleweed! I've never had to use DIV32 before so I appreciate the explicit examples.
    Everything works just fine now. The last thing I need to do is introduce linearization correction to get a better, more linear fade in. I think the info in this thread should help.
    Question: if the time it takes to calculate LEDBrVal is too long with DIV32, and I want to move to either using LOOKUP or a data table, can I have 2 data tables in one program?
    Tried this but it doesn't fade in the LED and I never get anything on the LCD screen after the counter to 100:
    ' For production version of this code, comment out the line below re:
    ' LCD debugging and also update config fuses to have code protect on
    #DEFINE USE_LCD_FOR_DEBUG     ; comment out for non-debug use
    ' Pin Connections
    ' VDD    -> pin 1            -> +5V
    ' RA5/Rc -> pin 2            -> EUSART receive
    ' RA2    -> pin 5            -> 1kohm -> 2N2222A transistor -> LEDs
    ' RA1    -> pin 6            -> Trim pot input
    ' RA0/Tx -> pin 7            -> EUSART transmit (LCD)
    ' VSS    -> pin 8            -> GND
    DEFINE OSC 16               ; Set oscillator 16Mhz
    ' EUSART Settings for Tx/Rc (e.g. LCD)
    ' > use Mister E PIC Multi-Calc application to get register/DEFINE settings
    ' > as the values are dependent on the OSC and desired baud rate
    DEFINE HSER_RCSTA 90h      ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h      ' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1      ' Clear overflow automatically
    DEFINE HSER_SPBRG 160      ' 9600 Baud @ 16MHz, -0.08%
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
       __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    ' Initialization
    OSCCON    = %01111000        ' 16MHz internal osc
    APFCON.2  = 0                ; Tx on RA0 for LCD display
    APFCON.7  = 1                ; Rc on RA5
    APFCON.0  = 0                ; CCP1 on RA2
    ' Some LCD serial modules need inverted data, some do not
    ' Enable the line below if needed, but for SparkFun SerLCD it should be
    ' commented out
    'BAUDCON.4 = 1               ; Transmit inverted data to the Tx pin
    ' From Mister E's Multi-Calc for EUSART:
    SPBRGH    = 1
    BAUDCON.3 = 1                ' Enable 16 bit baudrate generator
    TRISA     = %00100010	     ' Make all pins output except for RA1 (trim pot input)
                                 ' and RA5 (EUSART Rc)
    ANSELA    = %00000010        ; Analog on PORTA.1 (AN1) only
    FVRCON    = 0                ' Fixed Voltage Reference is disabled
    ADCON0    = %00000101        ' ADC (analog-to-digital) is enabled on AN1 (RA1) only
    PAUSEUS 20                   ; wait for the analog switch 'glitch' to die down
    ADCON1    = %00110000        ; Left-justified results in 8-bits; Frc as timer
    #IFDEF USE_LCD_FOR_DEBUG
        LCD_INST   CON 254       ' instruction
        LCD_CLR    CON 1         ' Clear screen
        LCD_L1     CON 128       ' LCD line 1
        LCD_L2     CON 192       ' LCD line 2
        LCD_SP_CMD CON 124       ' special command character (for adjusting backlight brightness or toggling splash screen)
        LCD_BR_LVL CON 140       ' 140==40%
        LCD_SPLASH CON 9         ' toggles splash screen display
    #ENDIF
    ADCInVal       VAR BYTE      ; stores ADCIN result read from trim pot
    compVal        VAR BYTE      ; stores last-changed ADC value
    CounterA       var BYTE		 ' Just a BYTE Temporary working variable
    DataW          var WORD		 ' Just a WORD Temporary working variable
    RawData        var BYTE [16] ' Array holding ADC Result
    LEDBrVal       VAR WORD
    i              VAR WORD
    ' Array size = 100
    ' Total PWM steps: 512
    ' Gamma correction: 1.35
    ' # of values per line: 25
    '-----[The data table]--------------------------------------------------------
    DataWord       VAR WORD
    DataTable      CON EXT
    GOTO OverData                ; Make sure data doesn't try to execute
    DataTable
      DW   0,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,  2,  2
      DW   3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  5,  5,  5,  6,  6,  6,  7,  7,  8,  8,  9,  9, 10, 11, 11
      DW  12, 13, 14, 15, 16, 17, 18, 20, 21, 23, 24, 26, 28, 30, 33, 35, 38, 41, 44, 47, 51, 55, 59, 64, 69
      DW  74, 80, 86, 93,101,109,118,128,138,150,162,176,190,206,224,243,263,286,310,337,366,398,433,471,511
    endasm
    OverData:
    '-----[Continue with code]----------------------------------------------------
    ' Set up PWM on CCP1
    CCP1CON = %00001100          ; Use CCP1 in PWM mode
    ' Set duty cycle registers initially to 0
    CCP1CON.4 = 0
    CCP1CON.5 = 0
    CCPR1L    = 0
    ' Use Mister E's PICMultiCalc_1.3.1.exe application (Windows only)
    ' to determine prescaler and PR2 values for given OSC frequency (e.g. 16Mhz)
    ' and duty cycle (use 100% to see highest actual value)
    ' CCP1 uses TMR2
    T2CON   = %00000110         ; Timer2 on with 1:16 prescaler
    PR2     = 127               ; For 16Mhz OSC the desired output freq of 1954Hz
                                ; is achieved with this PR2 value (9-bit resolution
                                ; with 1:16 prescaler)
                                ; MAX DUTY = 100
    MaxDuty       VAR WORD      ; According to Darrel:
                                ;   MaxDuty = (PR2 + 1) * 4
    MaxDuty = (PR2 + 1) * 4     ; 100
    MinDuty       CON 75        ; Minimum brightness for this application
    PWMDuty       VAR WORD      ; Duty cycle variable for PWM
    ' Fade in LED to set brightness
    FOR i = 0 to 100             ; must match ARRAY SIZE of data table above
        ReadCODE  (DataTable + i), DataWord
        PWMDuty = DataWord
        GOSUB ChngLEDBrightness
        pause 1
    NEXT i
        HSEROUT [LCD_INST, LCD_CLR]
        pause 5
        HSEROUT ["i=",DEC i,"  "]
    #ENDIF
        PAUSE 100
    GOTO Main
    '*********** Set duty registers ****************************************
    ChngLEDBrightness:
        CCP1CON.4 = PWMDuty.0
        CCP1CON.5 = PWMDuty.1
        CCPR1L    = PWMDuty >> 2
    I grabbed this scaling function from an Arduino library and was emulating that:
    '   Arduino Map function to emulate:
    '   map(value, fromLow, fromHigh, toLow, toHigh)
    '   long map(long x, long in_min, long in_max, long out_min, long out_max)
    '     return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    In general, the minimum brightness level is 0. But in this case, I only want to adjust the LED brightness between 50-100% duty cycle, so maybe I need to tweak that part as well.
  1. Weird PWM Behaviour on 16F1825
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 26th October 2012, 22:59
  2. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 23:18
  3. Strangw results when using PWM command
    Last Post: - 10th July 2006, 13:14
  4. Strange Results in Math
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 08:09
  5. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 15:21
