Weird ADC / Math Results with 9-Bit PWM
Results 1 to 22 of 22
    Aug 2011
    Default Re: Weird ADC / Math Results with 9-Bit PWM
    The problem is with this statement:
    LEDBrVal = (compVal - 0) * (MaxDuty - MinDuty)/(MaxADCVal - 0) + MinDuty
    If compVal = 255 then that evaluates to:
    LEDBrVal = 255 * 412/255 + 100
    255 * 412 = 105060, which is larger than a word (which has a max of 65535)
    105060 is $19a64, so the upper portion gets tossed out and you're left with $9a64 = 39524
    LEDBrVal = 39524/255 + 100
    LEDBrVal = 154 + 100
    LEDBrVal = 254
    That explains it, thanks very much. When I do the math by hand the 255's cancel each other out and then it's just 412+100.
    If I put brackets around the dividing part will that fix it?
    Aug 2011
    That'll truncate the division, leaving you with 412/255 = 1
    You can use PBPL mode so that it uses LONGs, which should work but it'll be larger and slower if that matters. Otherwise your best bet might be to turn the equation into a lookup table.
    To be honest, I don't use PBP much, so maybe others can suggest something else.
    Thanks again tumbleweed. I can't use PBPL without moving up to a 18F chip, and the minimum # of pins is then 18 (I only need two outputs so an 8-pin chip is ideal. Also, the PCB is pretty cramped now as it is).
    But a lookup table could be tricky given the 0-255 range of the 8-bit ADC input but a PWM duty cycle range of 512. Maybe I should switch to 10-bit ADC and just divide by 2?
    Why not look at using the DIV32 command?
    EN82fn
    Aug 2011
    That's an interesting operation. Splitting the equation up into two parts for DIV32 seems to work...
    LEDBrVal = ((compVal - 0) * (MaxDuty - MinDuty))
    LEDBrVal = DIV32 (MaxADCVal - 0) + MinDuty
    Is it safe to do something like that or would you suggest making the DIV32 statement simpler so that you know it immediately follows the multiplication (I don't know what the OP's intent for the " - 0" part of the above is for)?
    Yes, The way you have it is OK. Just remenber that the result of the first multiplication before the DIV32 is to a dumby variable and it won't be usefull after the DIV32 function. It should be sized as a word.
    EN82fn
    I grabbed this scaling function from an Arduino library and was emulating that:
    '   Arduino Map function to emulate:
    '   map(value, fromLow, fromHigh, toLow, toHigh)
    '   long map(long x, long in_min, long in_max, long out_min, long out_max)
    '     return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    In general, the minimum brightness level is 0. But in this case, I only want to adjust the LED brightness between 50-100% duty cycle, so maybe I need to tweak that part as well.
  1. Weird PWM Behaviour on 16F1825
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 26th October 2012, 21:59
  2. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 22:18
  3. Strangw results when using PWM command
    Last Post: - 10th July 2006, 12:14
  4. Strange Results in Math
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 07:09
  5. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 14:21
