how to setup MPLAB X 3.20 IDE ?
Results 1 to 7 of 7
    Jun 2008
    Varese , Italy
    Default how to setup MPLAB X 3.20 IDE ?
    Good day forum !
    I would like to use the MPLAB X 3.20 with my Picbasic Pro and the PicKit_3 programmer.
    Is there any tutorial on this matter?
    Any help is very much appreciated.
    Thanks in advance for the assistance.
    Ambro
    Jun 2008
    Varese , Italy
    Default Re: how to setup MPLAB X 3.20 IDE ?
    I read that the MPLABX versions greather than 3.0 have a problem with PBP and so I did download the 2.35 version now.
    I am now able to open .pbp files but I do have the following message:
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory 'D:/My_PIC/prj_active/pic4523_pwm_test'
    make -f nbproject/Makefile-default.mk dist/default/production/pic4523_pwm_test.production.hex
    make[2]: Entering directory 'D:/My_PIC/prj_active/pic4523_pwm_test'
    gnumkdir -p build/default/production
    "D:\pbp_250\PBPW.EXE" -ampasmx -n -k# -os -p18f4523 ttt.pbp
    make[2]: *** [build/default/production/ttt\.cof] Error -1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    Error - unrecognized input: #
    PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Bad command parameter. -n
    ERROR: Unable to execute MPLINK.EXE.Error linking file D:\My_PIC\prj_active\pic4523_pwm_test\ttt.O
    nbproject/Makefile-default.mk:91: recipe for target 'build/default/production/ttt\.cof' failed
    make[2]: Leaving directory 'D:/My_PIC/prj_active/pic4523_pwm_test'
    nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
    make[1]: Leaving directory 'D:/My_PIC/prj_active/pic4523_pwm_test'
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    BUILD FAILED (exit value 2, total time: 857ms)
    Any help please ?
    Thanks in advance.
    regards,
    Ambro
    I assume you have seen this
    http://www.picbasic.co.uk/forum/showthread.php?t=18520
    its about the best reference I have discovered.
    I still not sure mplabx is worth the effort but it does work
    my thoughts
    1. cannot comment/uncomment code blocks
    2. cannot code fold pbp code
    3. cannot insert breakpoints in asm code blocks (they always show as broken ). although you can instruction step through asm block
    4. can only view named byte sized vars anything else you need to view via ram address with no name just the address apita
    5. pickit3 is very fussy about powering things , need to use external supply for what a pickit2 does easily
    6. pickit3 goes stupid when I don't exit debug mode properly (my fault) and can need a unplug /restart
    7. no serial monitor (Atmel studio can do it)
    8. it can and does "hang" on my pc ,seems worse than mcs for hang frequency
    9. need to use mlabx friendly version of dt_ints18
    Jun 2008
    Varese , Italy
    Thanks Richard,
    I do understand now !
    Unfortunately i broke my old ICD_2 and now I have this pickit3.
    What free IDE will you suggest to me please ?
    regards,
    Ambrogio
    I use MCS with PBP3 compiler and in general a Elnec Pikprog+ (old, I know) programmer.
    But when I need t program chips with ICSP that Elnec does not support, I use Pickit3, with the stand alone application.
    MPLAB or MPLABX is a pain...
    Look for pickit 3 stand alone here: http://ww1.microchip.com/downloads/e....3%20Setup.zip
    I concur with Ioannis except where he uses a Elnec Pikprog I use pickit2
    mplabx only as a last resort and then usually only a cut down version of my code for debugging ,mcs is ok
    Jun 2008
    Varese , Italy
    OK,
    thanks Ioannis and Richard.
    Ambro
  1. Problem with MPLAB IDE v7.60
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 19th July 2011, 18:28
  2. A new MPLAB IDE
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 6th May 2011, 15:31
  3. Mplab x ide
    By fowardbias in forum Off Topic
    Last Post: - 3rd February 2011, 08:32
  4. MPLAB IDE (NewBee)
    By n7hri in forum mel PIC BASIC Pro
    Last Post: - 13th September 2009, 06:21
  5. MPLab IDE Project
    By BRINGERofBACON in forum General
    Last Post: - 3rd May 2008, 12:09
