Hi all,
I've been working with SD cards for a couple of years now, but only using Single Block Write. I'm trying to get Multiple Block Write to work but it fails after writing the first set.
Posting code will be difficult as it's a complicated program and would be easier if I started again, just to put something up to post.
What I've been trying so far is to use CMD25 and sending four blocks of data (4x 512 bytes) and then, once they've gone through, sending a single byte $fd using:
and then raising the CS line to, in theory, finish that set of block writes.Code:SDC_data_in = SSPBUF SSPIF = 0 SSPBUF = $FD While !SSPIF Wend
Then, when I wish to write another set of 4 blocks (at the next available address), I do the same as above, but, after the first 512 bytes go through, I get a data not accepted error ("Unknown fail"):
Does anyone have any code that successfully sets up a multiple block write to an SD card, terminates using the multiple stop token, and then successfully repeats this on the same card? I've been trying to do this for 3 days now with no success.Code:for cnt = 0 to 511 SDC_data_out = SDC_buffer[SDC_buffer_current_mul+cnt] gosub write_byte next cnt SDC_data_out = $ff gosub write_byte ' send 16 1s as a dummy CRC gosub write_byte SDC_data_in = SSPBUF ' clear the buffer SSPIF = 0 ' clear the interrupt flag SSPBUF = $ff ' shift out a dummy byte While !SSPIF ' wait for receive byte Wend SDC_data_in = SSPBUF ' get the byte If ((SDC_data_in & $0f) != DATA_ACCEPTED) Then SEROUT2 Serial_out,6,[$d,$a,"Unknown fail"] high red_led gosub stop_read endif
I also tried CMD12 but I got an Illegal Command error in the R1 response.
I have checked using a hex editor (changing the data it's writing each time to make sure it 'is' doing its job) that the 4 blocks are being written in the first multiple block write instance...
Best,
Jimbo
