Multiple Block Write SD protocol issue
Results 1 to 2 of 2
Threaded View
  1. #2
    Default Re: Multiple Block Write SD protocol issue
    Sorry for late reply, been away mostly, and have no knowledge about SD cards. But after doing some research for another thread, have you tried MeLabs SD Card SAMPLE program sdfs3.pbp?
    http://melabs.com/samples/PBP-mixed/sdfs3.htm
    ' Write to file
    	FAT_src[0] = "A"                               <<--------  Just load up your array as you see fit from element 0
    	FAT_src[1] = "B"
    	FAT_src[2] = "C"
    	FAT_count = 3                                  <<--------  set to 512
    	Gosub FSfwrite
    	Serout2 PORTC.6, 84, [ "Write ", Dec FAT_error, $d, $a]
    	If (FAT_error != 0) Then Stop
    This sample program does it all for you. Just note it's using PBPL and PIC 18 (but you probably already know this).
    If you absolutely have to use your own code (for whatever reason), SDFS.PBP might provide insight at what is the correct procedure.
    Or am I missing something obvious?
  1. Easy way to do multiple write statements ?
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 8th March 2016, 09:05
  2. Lcdout multiple variables issue
    By MarkEngineer in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2015, 15:51
  3. DT Multiple Software PWM and 18F2321 issue
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 20th December 2012, 09:23
  4. SD Multiple Write?
    By jimbostlawrence in forum General
    Last Post: - 21st October 2011, 18:45
  5. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
