Ds1820
Results 1 to 6 of 6
Thread: Ds1820
    Cool
    Why are you angry ??? DS 1820 is not responsible for any thing here ...
    You use a serial LCD and parallel devices command ... of course it can't work properly.
    Have a little look to serial commands like SEROUT ...
    puru's Avatar
    puru Guest
    Thanks for you reply but now I realize my post is not clear. The last line of the program I posted is not for the remote display. I do use serout but I'm not able to send temperature, that is a word, divided in multiple one byte. Before each one of these bytes I have also to send the row and location byte.
    puru's Avatar
    puru Guest
    For example if the temperature is 15.78 I have to send: row, location, 1 after that row, location, 5 and so on.
    Feb 2004
    Germany
    Assuming temperature is a word size variable and holds a value of 1578 (for 15.78 deg C)
    Use SEROUT2 with the DEC modifier. (See Manual Section 5.71)
    (SEROUT doesn't support modifiers)
    Also have a look at Manual Section 4.17.7
    DIG will solve your problem
    SEROUT2,Pin,Mode,[DEC1 temperature DIG 3,DEC1 temperature DIG 2,".",DEC1 temperature DIG 1,DEC1 temperature DIG 0," °C"]
    You will have to add the control-codes for your LCD to the code-example
    regards
    Ralph
    puru's Avatar
    puru Guest
    Smile
    Thank you very much Ralph for your solution. Despite all manuals, just now I can see a way to access the innard of temperature variable.
    Bert
  1. Please help with 1-wire DS1820
    By hatuan291 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2010, 14:51
  2. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  3. DS1820 and 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 19:11
  4. PIC lcd ds1820
    By wchpikus in forum mel PIC BASIC
    Last Post: - 24th May 2007, 15:46
  5. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 15:49
