Thanks Richard.
This has great potential in my code because as you commented, once I set close the realys to the trolley power all I have to do is loop through the routine that checks for a low sensor. To make it easier, the trolley dbeing on a track can only go in on direction at a time so in each stage of travel I know exactly which sensor to poll. Not like I would need an interrupt to see which of the three sensors went low. The time the magnet is over the reed switch is eon's compared to the rate at which the pic can poll the sensor line.
As I mentioned to one other reply, the pic advances to the next logical set of events just when the trolley gets moving and is several feet away from any sensor. This is what leads me to think some DC motor noise or even arcing of the pickup on the overhead wire is being picked up at the sensor pins and causing a false signal.
I will study your code and possibly with it and many of the other outstanding suggestions here, find a solution which I will gladly report on.
