Electrical Issue: PIC input false triggering, Signal Noise suspected.
Results 1 to 36 of 36
Threaded View
  1. #23
    Oct 2009
    Utah, USA
    Default Re: Electrical Issue: PIC input false triggering, Signal Noise suspected.
    @mark_s
    I would add that moving the reed switches a few inches away but leaving all the wiring as is would likely cause the reed switches to stop functioning but that is OK as it would allow you to determine if mark_s's theory holds true.
    If you still have false trigering then it was because of either the magnetic coupling or possibly vibration.
    At least that is what it seems you were getting at with your suggestion (or am I missing your point Mark?)
    @richard
    Here is how I devised a software debounce that would not block the rest of my main code loop
    if swflag = 1 and sw1=open then swflg = 0  '(sw debounce) clear swflg only when switch released
    if swflag = 0 and sw1=closed then   'sw1 button detected and valid
            swflag = 1      'set flag that switch has been closed
            (code goes here that you wanted the switch to do)
    (more main code loop goes here)
    GOTO Main
    it requires the swflag = 0 before it will acknowledge the sw1 is pressed. Other wise the switch will be ignored.
    the only way for swflag to return to 0 is for you to release sw1
    Dwight
  1. Intermittent reset of 16C6440 - possible noise issue
    Last Post: - 16th May 2012, 12:43
  2. Noise on input signal
    By fanman in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 02:55
  3. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 09:36
  4. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 19:26
  5. False Triggering I/O
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 17th July 2005, 09:02
