Electrical Issue: PIC input false triggering, Signal Noise suspected.
Results 1 to 36 of 36
Threaded View
  1. #15
    Default Re: Electrical Issue: PIC input false triggering, Signal Noise suspected.
    another way is to filter the input with a software routine
    reeds var byte
    reeds_flg var byte
    reed_1_active var reeds_flg.0
    reed_2_active var reeds_flg.1
    reed_3_active var reeds_flg.2
    reed_cnt var byte[3]
    reed var byte
    define reed_threshold 64
    chk_reeds:
    reeds=portc & $70  ;c4 c5 c6  active low
    if reeds < 112 then
    reeds=reeds >> 4
    for reed = 0 to 2
    if ! reeds.0 then
            reed_cnt[reed]=reed_cnt[reed]+1
            if reed_cnt[reed]> reed_threshold then reeds_flg.0[reed]=1
            reed_cnt[reed]=0
    reeds=reeds>>1
    next
    if you call the chk_reeds subroutine regularly (must be regular) say in this case 100 times per second, then if a reed input is consistently low for 64 (counts in a row the reed_threshold) then the reed_x_active flag will be set.
  1. Intermittent reset of 16C6440 - possible noise issue
    Last Post: - 16th May 2012, 12:43
  2. Noise on input signal
    By fanman in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 02:55
  3. Electrical noise problem with PIC 16f84
    By Snap in forum General
    Last Post: - 26th September 2007, 09:36
  4. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 19:26
  5. False Triggering I/O
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 17th July 2005, 09:02
