AC and DC how to?
Results 1 to 11 of 11
    Scott's Avatar
    Scott Guest
    Default AC and DC how to?
    I would like to allow my circuit to take both AC or DC power. Does anyone have an example schematic on how to do this? Links? I am used to using a full bridge or just a regulator but never both.
    Thanks in advance,
    Scott
    Feb 2004
    Germany
    If you have your circuit designed for AC (bridge rectifier + caps + regulator)
    You can supply it with DC,
    and you do not even have to care about the polarity of your DC supply
    or voltage (AC or DC) as long as it is within the specs of your regulator
    Quote Originally Posted by Scott
    ...I am used to using a full bridge or just a regulator but never both.
    How do you ensure a clean and stable supply voltage of an AC powered circuit with only a bridge and no regulator?
    regards
    Ralph
    Scott's Avatar
    Scott Guest
    Thanks!
    I always have a regulator regardless AC or DC. I was not clear in my post. I have a bridge, cap and a standard LDO 12v regulator rated at 35V input. So if I connect it to a 24Vdc power supply it will be fine?
    Feb 2004
    Germany
    Thanks!
    ...So if I connect it to a 24Vdc power supply it will be fine?
    Yes, it will,
    and even the DC polarity doesn't matter.
    regards
    Ralph
    Feb 2004
    Germany
    Your post was very clear,
    you said there is no bridge in combnation with a regulator:
    regards
    Ralph
    Porto - Portugal
    Exclamation
    Hi
    Scott, Bruce is wright (as always), but do not forget that using a LDO with that voltage difference (24 volt to 12 volt) even a little current will generate a lot of heat at LDO metallic tab, please use a suitable heatsink.
    Only wishing to help.
    Best regards for both,
    nomada
    nomada
    Porto - Portugal
    Hi
    Just want to say that I mean to say RALPH (not Bruce) sorry about the confusion.
    nomada
    nomada
  1. DC to AC convertor
    Last Post: - 6th February 2010, 18:44
  2. 600w dc to ac invertor
    By marsh in forum Forum Requests
    Last Post: - 16th August 2008, 18:04
  3. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  4. DC - AC Solid State Relay
    By shahidali55 in forum General
    Last Post: - 10th November 2007, 17:01
  5. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
