You know me.
Ah, awesome! I don't think I'll care for the older version once I've finished migrating at least one working test program over. After that, I'll just copy that CONFIG.If you don't ALSO want any of the older versions installed just forget about them now and install PBP3, done.
And this is why I was lost. "Upgrade" CDs for me always had partial data or required you entered the old CD as validation during install.It's called an upgrade only because you've already payed for an older version - what's on the actual DISC is exactly what you'd get if you bought it "new". I know this isn't always the case with other software but with PBP3 it is, in my experience.
Perfect. I'll probably have it on a desktop later at some point. But for now I just want to be up and running on this new laptop.Once installed run the licence manager to activate your license. If I'm not mistaken you can have your licence active on two machines at once. If you need to change machine run the licence manager and de-activate the licence on the machine you're getting rid of in order to free it up.
Thanks Henrik.
