SSPCON registers not being recognized on 18F2550
Results 1 to 3 of 3
    Sep 2006
    Indiana, USA
    Default SSPCON registers not being recognized on 18F2550
    I'm using PBP3 (MPLAB 8.9) with a 18F2550 and trying to use the SSPCON registers to set it up for hardware SPI. I get bad data type error. Is SSPCON not supported on this chip?
    I've also tried it with 2.60C and no luck there.
    Any help is appreciated
    Default Re: SSPCON registers not being recognized on 18F2550
    would you actually mean SSPCON1 the chip has no SSPCON reg
    Richard is spot on. The 2550 have two MSSP modules so there are two SSPCON registers.
    I've found that sometimes MeLabs have aliased the SSPCON to SSPCON1 so code written for devices with one MSSP module would still work on devices with two but apparently not so on this device.
    As always, when i doubt read the datasheet and by all means look at the .PBPINC files where all the registers that PBP is made aware of is being declared.
  1. statment not recognized
    By xvladx in forum General
    Last Post: - 10th April 2010, 14:07
  2. device not recognized
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st November 2009, 17:21
  3. 18F4431 SSPCON.5 syntax error
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2009, 11:17
  4. SSPCON and 18F2431 Problem
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 11th November 2008, 16:19
  5. Replies: 3
    Last Post: - 22nd January 2008, 03:48
