PWM of voltage input to PIC - will it damage the chip?
Results 1 to 9 of 9
    Default Re: PWM of voltage input to PIC - will it damage the chip?
    PIC will not be hurt. But as Amoque noted, it will keep reseting because it cannot work from 0 volts, right?
    You have to make new electric connections.
    The board is only 1.5" in diameter and I don't think I can fit anything more on it:
    I don't think the PIC restarting is a problem since all it does is blink 5 LEDs at separate rates, so if it's turning-on-and-turning-off then that could look OK.
  1. Replies: 7
    Last Post: - 22nd January 2012, 05:50
  2. 30 PWM outputs on one chip?
    Last Post: - 25th September 2009, 17:32
  3. Temp readings and voltage input
    Last Post: - 7th July 2008, 13:35
  4. Lowest readable input voltage?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 7th January 2008, 11:12
  5. measuring input voltage
    By thon in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 17:03
