4 DAC channels from a single PIC
Results 1 to 6 of 6
    Jun 2007
    Mansfield, UK
    Default 4 DAC channels from a single PIC
    Hi, I'm working on a project that requires 4 audio outputs from DACs but I can't find any suitable.
    DAC requirements:-
    8-bit minimum resolution
    16-bits of data per channel max. My PIC only has an 8-byte SPI buffer
    3.3V
    Each channel must be aligned to an 8-bit boundary
    My main concern is the amount of clock cycles the PIC can use communicating with the DACs. Ideally I would like to queue all of the data into the PIC's SPI buffer and exit the interrupt routine.
    I can pulse the latch pin at the start of the next interrupt but all of the DACs I've seen require the CS line to be toggled between each message. Even a single DAC with 4 channels requires CS to be toggled 4 times.
    I don't have enough clock cycles to wait in the interrupt while the data is sent or to keep jumping in and out of interrupts between each byte.
    Does anyone know of a 4 channel DAC that will allow me to simply shift 4 bytes into it? Failing that, I would be happy with 4 x single channel DACs that can be daisy chained so they don't require individual CS control.
    I've also considered a hardware solution. Is there such thing as an SPI splitter that would allow me to shift 4 bytes into it and have each byte shifted out of 4 separate data lines?
    Bombay, India
    Default Re: 4 DAC channels from a single PIC
    Not sure if this is helpful, but,....
    What if you daisy chain 4 HC595 or similar serial - parallel shifters? Each 595 in turn could drive a R-2R ladder or simply jam its 8 bits into a parallel loaded single DAC.
    Out of curiosity, which PIC has an 8-byte SPI buffer?
    Jun 2007
    Mansfield, UK
    Jerson: That's a good idea. As long as I can somehow clock the data into the shift register then toggle a line to load the current state into the DAC then that should work perfectly (I will do some reading on this). I can get hold of parallel DACs easier too! Thanks
    Henrik: I work with PIC24FJ64GA002/PIC24FJ64GA004 chips. It's possible to fire 9 bytes at the SPI module in one go. The first byte moves straight to the shift register leaving all 8 slots in the FIFO available.
    Ah, that's what I suspected, not an 8-bit PIC. To bad, that could be useful with PBP.
    Thanks!
    One day dream might come true...
  1. Single PIC to Blink 5 LEDs Independently?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 18th July 2015, 16:56
  2. Replies: 76
    Last Post: - 11th November 2014, 05:46
  3. Trade - Swap other PIC/s for single 18F2550
    By mr.sneezy in forum Adverts
    Last Post: - 25th February 2009, 07:44
  4. Single PIC As Both, Wireless Transmitter and Receiver
    By charlieb83 in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2007, 04:35
  5. Bluetooth wireless with PIC / HSERIN / DAC
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 22:13
