different software times, impossible?
Results 1 to 39 of 39
    Default Re: different software times, impossible?
    i tried with only 4us of "off" state and the input pin of the ic connected to the pic count the clock pulses very good, like the datasheet says
    it work with even 1us off state
    Bombay, India
    Are you looking to implement a frequency multiplier using PIC ?
    oh no, it's a stepper motors driver
    Bombay, India
    Well okay, a stepper motor driver should not be difficult to implement. You are possibly asking for some kind of multiplication factor between an input wave (encoder) and the output drive(Stepper). I'm not sure I understand the problem you described very well.
    simply the stepper motor driver use the input clock to define the steps, one rising pulse is one step, 400 rising pulses are 400 steps
    So the PIC is what's going to generate the pulses for two step motor drivers and you're trying to implement linear interpolation in the PIC?
    Generally what you're looking for is Breshenhams algorithm but your case seems rather specific with one axis always moving the same distance so I don't know.
    if i choose the two pic serially connected solution the two separate quartz can produce an error in time or it will be negligible?
  1. WDT times not as expected 18f46k80
    Last Post: - 18th July 2015, 05:22
  2. MCSP, PBP260, Win7 - is it impossible?
    By HenrikOlsson in forum General
    Last Post: - 26th January 2010, 18:08
  3. Drive relay between two times
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 15th December 2009, 10:19
  4. Instruction times
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th June 2009, 10:16
  5. Calling Subroutines Multiple Times
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 08:11
