so wave 1 is 400 pulses of [ pulse width x] : therefore duration = x * 800
wave 2 is y pulses of duration/(y*2) ; assuming 50% duty
y range is ?
x range is ?
tolerance is ?
repeat rate is ?
y range is ?
x range is ?
tolerance is ?
repeat rate is ?
the only fixed thing is the 400 pulses of the x, with 300us on and 300us off, on the other side y i must have the choice to set different pulses (100 to 600). But whatever pulses have the y the goal must be to reach the end at the same time....
how do you define the end ?But whatever pulses have the y the goal must be to reach the end at the same time....
depending on what you think a reasonable resolution is (and achievable) not all possible pulse counts in the range 100-600 will divide exactly into the duration .
what is the duration 800 * 300 uS or 799 * 300 uS ?
how do you intend the sync to be eg leading edge low to high transition to trailing edge high to low transition ?
can the final y pulse just be truncated to fit ?
hello richard, first of all thank you. The y pulse can be always approximate to the unit, so it's never truncated. Only the pause change to reach the total time together at the x pulse. the x pulse is fixed 400*600=240000=240milliseconds, so the y pulses.
i will make a test to see if the logical circuit connected to the pic accept "on" states duration other than "off" states, not symmetrical. Cause if the only important thing is the distance between the beginning of every "on" state maybe the software can be easier....
It is, I understand, also possible to run more than one pic from a clock source. You mentioned connecting pics serially, but I do not see this as a solution; however, two (or more) sync'ed to the same clock...
this is what the datasheet of the ic connected to the pic says:
"An active low pulse on the input pin activate the logic. The activation occurs on the rising edge of the signal"
clock input pin: low max 0,6v, high min 2v
clock time: 0,5 us
set up time: 1 us
hold time: 4 us
i tried with only 4us of "off" state and the input pin of the ic connected to the pic count the clock pulses very good, like the datasheet says
