Testing PortB pin
Results 1 to 3 of 3
    Apr 2004
    Question Testing PortB pin
    Hi there,
    I'm struggling a bit with testing the status of PortB pin of a Pic16F876A.
    I want to be able to read the state of one of the pins of PORTB based upon a variable.
    DEFINE LOADER_USED 1
    DEFINE OSC 10
    Green var PORTA.0 ' Led 2
    Data_1 var byte
    ADCON1=$07
    TRISB=%00000000
    Init:
    high green
    pause 2000
    low green
    data_1 = 5
    test:
    if PortB.0(data_1) = 0 then
    --> LCD should show "Low"
    --> LCD should show "high
    pause 2000
    goto test
    When I use 'Data_1' as a variable with PortB it doesn't seem to work.
    Is there a solution or workaround for this?
    Data_1 can be from 0 to 7.
    TRISB = %00000000 sets portb as outputs. Try TRISB = $FF and see how it
    responds.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2004
    Bruce,
    Thanks got it sorted out.
    Appologies for the late reply
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:11
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
