18F4550 issue with simple program.
Results 1 to 12 of 12
    Feb 2004
    Michigan, USA
    Default Re: 18F4550 issue with simple program.
    I cant seem to get some of the ADC readings to write to EEPROM. Channels 0 and 1 work perfectly the others write anything. Any idea whats going on? I think all the ports are set correctly.
    Define OSC 48
    Define ADC_BITS 10 ' Set number of bits in result
    adval var word ' Create adval to store result
    adval1 var word
    adval2 var word ' Create adval to store result
    adval3 var word
    adval4 var word ' Create adval to store result
    adval5 var word
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00000000 ' Set PORTA analog and right justify result
    ADCON2.7=1
    TRISB = %00011111
    TRISC = %00000000
    TRISE = %00001111
    RCSTA.7 = 0
    loop1:
    ADCIN 0, adval
    pause 1
    write 0, adval
    adcin 1, adval1
    pause 1
    write 1, adval1
    adcin 2, adval2
    pause 1
    write 2, adval2
    adcin 3, adval3
    pause 1
    write 3, adval3
    adcin 4, adval4
    pause 1
    write 4, adval4
    adcin 5, adval5
    pause 1
    write 5, adval5
    SEROUT PortC.6,2,[adval, adval1, adval2, 10]
    portc.6 = 0
    portc.7 = 0
    pause 200
    goto loop1
    adval1 var word
    adval3 var word
    adval5 var word
    pause 1
    write 0, adval
    adcin 1, adval1
    pause 1
    write 1, adval1
    how many bytes in a word ?
    Jmgelba, you need to index the memory pointer by 2 for it to store a word or, something like this:
    write 1, adval1.lowbyte
    write 2, adval1.highbyte
    then you can read them back by using:
    READ 1,value to read the entire word.
    EN82fn
  1. USB issue - 18F4550
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 20th February 2013, 21:49
  2. 18F4550 issue
    Last Post: - 4th February 2013, 07:27
  3. Simple LED driving issue - setup?
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th March 2011, 02:54
  4. Code issue with a flashing light(simple question)
    By IAmTheAnswer in forum mel PIC BASIC Pro
    Last Post: - 8th May 2010, 12:46
  5. Simple 4 line LCD display with 18F4550
    By pic-ker in forum Code Examples
    Last Post: - 9th April 2007, 03:58
