Not sure if this helps, but this is a section of code that uses an 18f4580, with four pots on port A
; config settings 18F2550/4550/18F4580, 20mhz crystal
  __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
  __CONFIG    _CONFIG2L, _PWRT_ON_2L
  __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
  __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
DEFINE  OSC 48
ADCON1 = $0F
clear
DEFINE ADC_BITS 10                              ' Set-up ADC for fastest 10-bit results
DEFINE ADC_CLOCK 2
DEFINE ADC_SAMPLEUS 5
INCLUDE "DT_Analog.pbp"
MaxSetPoint  CON 500                            ' Pot fully clockwise - gives max setting 50 degrees
MinSetPoint  CON 100                            ' Pot fully counter clockwise - sets min setting 10 degrees
ADbits = 14                                     ' set A/D resolution to 14-bits
CMCON = 7                                       ' disable Comparators
ADCON1 = %00001011                              ' sets up Analogue pins
ADCON2.7 = 1                                    ' ADFM bit isn't in ADCON1 anymore
;----[Port settings]----------------------------------------------------
TRISA = %11001111
It uses DT's analogue include file, which might be worth downloading and including in your own code
