word larger numbers
Results 1 to 7 of 7
    Default word larger numbers
    I have to multiply a byte for the word fixed 10000, and then divide the result by the fixed word 312 (example 73x10000 / 312). How can i do this when the result of the multiplication exceeds the maximum content of a word?
    Default Re: word larger numbers
    dummy_word_var = 73*10000
    result_word_var= div32 312
    [result=2339]
    Or perhaps
    73 */ 8205
    Result = 2339
    Or, if precision isn't THAT critical, since 10000/312 = 32.0513 which is pretty close to 32:
    73 <<  5
    Result = 2336
    Where obviously the last one will be the smallest and fastes option
    but 73000 isnt' larger than a word?
    never mind
    Sep 2009
    PBP uses internal 32bit register for storing results(registers R1,R2,R3,R4 if I remember correctly). Maximum number that can be stored is 4294967295
    Then DIV32 divide register with 312 in this example.
    Jan 2010
    PHILADELPHIA, PA - USA
    Look into Alexander Avtanski's N-Bit Math which is mentioned in this old post
    http://www.picbasic.co.uk/forum/showthread.php?t=12433
    Wozzy-2010
  1. how can I caculate with numbers bigger than a word using 16F88 ?
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 17th May 2010, 03:51
  2. Displaying a decimal larger than 255 on LCD?
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 10:02
  3. convert the numbers to word
    Last Post: - 12th April 2007, 09:00
  4. Larger array possible if I move to 18Fxxx?
    By incognico in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 16:03
  5. Array larger than 256 bytes
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 16:38
