Well...it was swapped pins on the x-bee module header. It was my mistake for grabbing one already soldered up and not checking the pin-out.
Thanks for all the suggestions, here is the code
'*  Author  : Mike Mummert                                      *
'*  Notice  : Copyright (c) 2016 All Rights Reserved            *
'*  Date    : 1/9/2016                                          *
    INCLUDE "modedefs.bas"
    include "ALLDIGITAL.pbp"
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    OSCCON =$60 'clock speed
    Define PULSIN_MAX 1000
    DEFINE HSER_RCSTA 90h   'Hser receive status init
    DEFINE HSER_TXSTA 24h   'Hser transmit status init
    DEFINE HSER_BAUD 9600  'Hser baud rate
    define HSER_SPBRG 25
    Define HSER_CLROERR 1
    INTCON = %11000000
    TRISC =  %10000000
    ADCON1 = %00001111
   ' DEFINE DEBUG_REG PORTB
    'DEFINE DEBUG_BIT 3
   ' DEFINE DEBUG_BAUD 9600
    'DEFINE DEBUG_MODE 1
DQ              VAR     PortA.1               ' 1-Wire buss pin
tX              var     PortC.6
rX              var     PortC.7
Baud            CON     84 ' 9600 baud, non-inverted
RdROM           CON     $33             ' read serial number
MatchROM        CON     $55             ' match SN -- for multiple devices
SkipROM         CON     $CC             ' ignore SN -- use for one device
CvrtTmp         CON     $44             ' start temperature conversion
RdSP            CON     $BE             ' read DS1822 scratch pad
tempIn          VAR     Word            ' raw temperature
sign            VAR     tempIn.BIT11    ' 1 = negative temperature
tLo             VAR     tempIn.BYTE0
tHi             VAR     tempIn.BYTE1
tSign           VAR     Bit             ' saved sign bit
tempC           VAR     Word            ' final Celsius temp
tempF           VAR     Word            ' final Fahrenheit temp
Panel           VAR     Word
Tank            VAR     Word
Nb_var21        var     byte
Nb_var22        var     byte
Nb_varH23       var     byte
Nb_varM23       var     byte
Nb_var24        var     byte
Nb_varH27       var     byte
Nb_varM27       var     byte
Nb_var28        var     byte
Nb_varH59       var     byte
Nb_varM59       var     byte
Nb_var60        var     byte
Nb_var31        var     byte
Nb_var32        var     byte
Nb_varH33       var     byte
Nb_varM33       var     byte
Nb_var34        var     byte
Nb_varH37       var     byte
Nb_varM37       var     byte
Nb_var38        var     byte
Nb_varH63       var     byte
Nb_varM63       var     byte
Nb_var64        var     byte
Nb_var41        var     byte
Nb_var42        var     byte
Nb_varH43       var     byte
Nb_varM43       var     byte
Nb_var44        var     byte
Nb_varH47       var     byte
Nb_varM47       var     byte
Nb_var48        var     byte
Nb_varH67       var     byte
Nb_varM67       var     byte
Nb_var68        var     byte
hour            var     byte
Minute          var     byte
day             var     byte
        INT_Handler    RX_INT,    _read_serial,   PBP,  yes
    INT_CREATE             ; Creates the interrupt processor
T0CON = %10010010
@   INT_ENABLE   RX_INT     ; enable external (RX) interrupts
    serout2 PortB.4,16468,[1,"DS1822  ", CR,"------", CR,SDEC Panel, " Panel ", CR,SDEC Tank,  " Tank ",cr, dec Nb_var21, " DR temp "]                         ' display
Get_Temperature:
  OWOUT DQ, 1, [ MatchRom,$28,$D4,$04,$60,$07,$00,$00,$F3]  'Match serial number to your device
  OWOUT DQ, 0, [ CvrtTmp]                ' send convert temperature command
  DO                                    ' wait on conversion
    PAUSE 25                            ' small loop pad
    OWIN DQ, 4, [tempIn]                ' check status (bit transfer)
  LOOP UNTIL (tempIn)
  OWOUT DQ, 0, [ RdSP]                  ' read DS1822 scratch pad
  OWIN  DQ, 2, [tLo, tHi]               ' get raw temp data
  tSign = sign                          ' save sign bit
  tempC = tempIn >> 4                   ' round to whole degrees
  tempC.BYTE1 = $FF * tSign             ' correct twos complement bits
  tempF = (ABS tempC) * 9 / 5           ' start F conversion
  IF (tSign) THEN                       ' finish F conversion
    tempF = 32 - tempF                  ' C was negative
    tempF = tempF + 32                  ' C was positive
  Panel = tempF
   OWOUT DQ, 1, [ MatchRom,$28,$34,$AF,$5F,$07,$00,$00,$4B]
  LOOP UNTIL (tempIn)
  tank = tempF
read_serial:
    hserin 1000,timeout,[WAIT (":"),Nb_var22,Nb_var21,Nb_varH23,Nb_varM23,Nb_var24,Nb_varH27,Nb_varM27,Nb_var28,Nb_varH59,Nb_varM59,Nb_var60]
    hserin 1000,timeout,[WAIT (":"),Nb_var31,Nb_var32,Nb_varH33,Nb_varM33,Nb_var34,Nb_varH37,Nb_varM37,Nb_var38,Nb_varH63,Nb_varM63,Nb_var64]
    hserin 1000,timeout,[WAIT (":"),Nb_var41, Nb_var42,Nb_varH43,Nb_varM43,Nb_var44,Nb_varH47,Nb_varM47,Nb_var48,Nb_varH67,Nb_varM67,Nb_var68, hour, minute,Day ] 'get temp setting from Master
Send_serial:
     hserout [dec tank, dec panel]'send info to Master
     serout2 PortB.4,16468,[1,"got data"]
     pause 2000
@ INT_RETURN
timeout:
RCSTA.4=0
RCSTA.4=1
serout2 PortB.4,16468,[1,"error    "]
pause 2000
@ INT_RETURN
