Is there a more efficient way?
Results 1 to 8 of 8
    the use of LOOKUP, READ will be easier and faster... some home work to do but ... just an idea
    Wink
    Hi, Mark edwards
    Considering the thermistor's value tolerance ( generally +/- 20%, 10% in the best cases ) , plus it's precision, linearity, and repeatability ...
    on that a small range , a simple y = ax + b linéarisation will give a widely credible result !!!
    I disagree. Banks of IF statements are real ugly and there are more elegant ways of doing the same thing, but those heaps of IF statements invariably outperform the more elegant solutions.
    There is room for improvement, not in performance as in speed per se, but in resolution. You could almost interpolate steps of about a quarter of a degree (or better)... look...
    if AD0 >= 446 then RA = 67
    if AD0 >= 450 then RA = 68
    You've got about four clicks or more...
    if AD0 >= 535 then RA = 82
    if AD0 >= 544 then RA = 83
    between adjacent degrees... you have enough data to increase your resolution to beyond 1F. No, not with banks of IF statements this time, you need to be a little more creative with the math. If you can't figure it, come back and I'll show you how.
    Wink
    Hi, Mel
    I Agree for the ( basic ...) maths.
    As no sensor calibration is evoked ... the result could be, i.e.
    70°F +/- 10°F ... ( remember the thermistor nominal value tolerance !!! )
    what is the sense of the 1/4°F here ...
    Ah, Yesssss, I see ... a smart looking gadget !!!
    Not so easy, the precise measurements .... don't you think???
    As long as it looks good and appears to function...
    More than half the stuff you see for sale is total rubbish... however the secret of success is being fastest to market with your particular piece of land-fill...
    And now i agree
    Many people think that because it's electronic it's more accurate ... well sometime !!!
    Feb 2004
    Germany
    Quote Originally Posted by mister_e
    ...Many people think that because it's electronic it's more accurate ...
    ...and the more decimals there are on the display the better it is...
    regards
    Ralph
  1. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 06:53
  2. Transformerless Power Suppply
    By ERIK in forum Schematics
    Last Post: - 3rd September 2012, 15:08
  3. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 13:37
  4. Efficient Fixed-Point Trigonometry For PIC16F
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 9th September 2009, 01:50
