I can not a reading sensor lm35
could someone help me out here the code I'm using
I must read 4 sensor lm35
'USB CDC DEMO sample program for PIC18F4550 CDC serial port emulation
'Compilation of this program requires that specific support files be
'available in the source directory.You may also need to modify the
'file USBDESC.ASM so that the proper descriptor files are included. For
'detailed information, see the file PBP\USB18\USB.TXT.
asm
__CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
__CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
__CONFIG _CONFIG2H, _WDT_OFF_2H
__CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
__CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
endasm
DEFINE OSC 48
DEFINE LOADER_USED 1
DEFINE RESET_ORG 1000h 'For Microchip USB Bootloader
buffer Var Byte[16]
cnt Var Byte
sw var byte
ch var byte
adval var word 'ADC values 10 bit
led var portb.0
'ADC parameters
DEFINE ADC_BITS 10 'Number of bits in ADCIN result
DEFINE ADC_CLOCK 3 'ADC clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50 'ADC sampling time in microseconds
TRISA = %11111111 ' Set PORTA to all input
ADCON1 = %00001010 ' Set PORTA analog and right justify result, PORTE digital
'***** MAIN PROGRAM ******
START:
'Initialize
USBInit
'Wait for USB input
idleloop:
USBService 'Must service USB regularly
cnt = 16 'Specify input buffer size
USBIn 3, buffer, cnt, idleloop
sw = buffer[0]
'Message received
Toggle LED
select case sw
case "1"
'Read and send ADC values
ADCIN 0,adval
adval = adval*48
adval = adval/100+1
pause 50
ch = "1"
gosub adc2buff
case "2"
ADCIN 1,adval
adval = adval*48
adval = adval/100+1
pause 50
ch = "2"
gosub adc2buff
case "3"
ADCIN 2,adval
adval = adval*48
adval = adval/100+1
pause 50
ch = "3"
gosub adc2buff
case "4"
ADCIN 3,adval
adval = adval*48
adval = adval/100+1
pause 50
ch = "4"
gosub adc2buff
end select
outloop:
USBOut 3,buffer,15,outloop
Goto idleloop 'Wait for next buffer
'Subroutines
Adc2Buff:
buffer[0]="A"
buffer[1]="d"
buffer[2]="c"
buffer[3]= ch
buffer[4]="="
buffer[5]=(adval dig 2)
buffer[6]=(adval dig 1)
buffer[7]=(adval dig 0)
buffer[8]=13
buffer[9]=10
buffer[10]=0
