DT_Interupts with 18F2525
Results 1 to 7 of 7
    Jul 2009
    Ohio, USA
    Default DT_Interupts with 18F2525
    Been trying to get RX_INT to work with 18F2525, I can get it with 18F1320 but I seem to be missing something. Any help would be great...
    Here is what I have
        INCLUDE "modedefs.bas"
        Include "ALLDIGITAL.pbp"
        INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
        OSCCON =$60 'clock speed
        DEFINE HSER_RCSTA 90h   'Hser receive status init
        DEFINE HSER_TXSTA 24h   'Hser transmit status init
        DEFINE HSER_BAUD 9600  'Hser baud rate
        Define HSER_SPBRG 25
        Define HSER_CLROERR 1
            INT_Handler    RX_INT,    _read_serial,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    @   INT_ENABLE   RX_INT     ; enable external (RX) interrupts
    The Fuses are set as:
    __CONFIG _CONFIG1H, _OSC_INTIO67_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & 0bfh ;_XINST_OFF_4L
    Thanks in advance
    Default Re: DT_Interupts with 18F2525
    Have you verified that the PIC is running at the desired (4MHz) speed? OSCCON=$60 doesn't look quite right to me.
    Have you checked that the serial connection works and that you can recieve data in a non interrupt driven way, ie by using HSERIN for example?
    Not sure if it's related or nor but generaly you don't want DT-Ints to reset the interrupt flag because it gets reset automatically by the hardware when the RCREG is read.
    Jul 2009
    Ohio, USA
    Hi Henrik,
    The Pic is running at 4 MHz with internal xtal. I can receive serial with SERIN2, will try HSERIN.
    The ASM interrupt will not trip and go to label Read_serial:
    At work at the moment; Will confirm that I have TX and RX on the right pins when I get home and keep you updated
    Have you actually verified that? The fact that SERIN2 works indicates that you have and it is but I must ask again because as far as I can see (looking at this datasheet setting OSCCON=$60 selects 1MHz and you don't have the PLL enabled (which only works when 4 or 8MHz is selected anyway) - if I read the datasheet correct of course.
    Then you say that the ASM interrupt won't trip, but you have the type set to PBP (and you don't show the handler).
    Anyway, make sure you can recieve using HSERIN, when that works properly go back to the interrupt driven stuff.
    EDIT: By the way, setting the baudrate and other settings using DEFINEs doesn't seem to actually do anything until you include a HSEROUT/HSERIN statement in the code. Instead of doing the DEFINE method try setting the registers directly and see if that makes any difference.
    Dec 2010
    The problem might also be in your interrupt handler, or several other places. You should post all the code.
    could also check the serial data polarity coming to pic..... may need inverted
    Jul 2009
    Ohio, USA
    Well...it was swapped pins on the x-bee module header. It was my mistake for grabbing one already soldered up and not checking the pin-out.
    Thanks for all the suggestions, here is the code
    '*  Author  : Mike Mummert                                      *
    '*  Notice  : Copyright (c) 2016 All Rights Reserved            *
    '*  Date    : 1/9/2016                                          *
        include "ALLDIGITAL.pbp"
        Define PULSIN_MAX 1000
        define HSER_SPBRG 25
        INTCON = %11000000
        TRISC =  %10000000
        ADCON1 = %00001111
       ' DEFINE DEBUG_REG PORTB
        'DEFINE DEBUG_BIT 3
       ' DEFINE DEBUG_BAUD 9600
        'DEFINE DEBUG_MODE 1
    DQ              VAR     PortA.1               ' 1-Wire buss pin
    tX              var     PortC.6
    rX              var     PortC.7
    Baud            CON     84 ' 9600 baud, non-inverted
    RdROM           CON     $33             ' read serial number
    MatchROM        CON     $55             ' match SN -- for multiple devices
    SkipROM         CON     $CC             ' ignore SN -- use for one device
    CvrtTmp         CON     $44             ' start temperature conversion
    RdSP            CON     $BE             ' read DS1822 scratch pad
    tempIn          VAR     Word            ' raw temperature
    sign            VAR     tempIn.BIT11    ' 1 = negative temperature
    tLo             VAR     tempIn.BYTE0
    tHi             VAR     tempIn.BYTE1
    tSign           VAR     Bit             ' saved sign bit
    tempC           VAR     Word            ' final Celsius temp
    tempF           VAR     Word            ' final Fahrenheit temp
    Panel           VAR     Word
    Tank            VAR     Word
    Nb_var21        var     byte
    Nb_var22        var     byte
    Nb_varH23       var     byte
    Nb_varM23       var     byte
    Nb_var24        var     byte
    Nb_varH27       var     byte
    Nb_varM27       var     byte
    Nb_var28        var     byte
    Nb_varH59       var     byte
    Nb_varM59       var     byte
    Nb_var60        var     byte
    Nb_var31        var     byte
    Nb_var32        var     byte
    Nb_varH33       var     byte
    Nb_varM33       var     byte
    Nb_var34        var     byte
    Nb_varH37       var     byte
    Nb_varM37       var     byte
    Nb_var38        var     byte
    Nb_varH63       var     byte
    Nb_varM63       var     byte
    Nb_var64        var     byte
    Nb_var41        var     byte
    Nb_var42        var     byte
    Nb_varH43       var     byte
    Nb_varM43       var     byte
    Nb_var44        var     byte
    Nb_varH47       var     byte
    Nb_varM47       var     byte
    Nb_var48        var     byte
    Nb_varH67       var     byte
    Nb_varM67       var     byte
    Nb_var68        var     byte
    hour            var     byte
    Minute          var     byte
    day             var     byte
    T0CON = %10010010
        serout2 PortB.4,16468,[1,"DS1822  ", CR,"------", CR,SDEC Panel, " Panel ", CR,SDEC Tank,  " Tank ",cr, dec Nb_var21, " DR temp "]                         ' display
    Get_Temperature:
      OWOUT DQ, 1, [ MatchRom,$28,$D4,$04,$60,$07,$00,$00,$F3]  'Match serial number to your device
      OWOUT DQ, 0, [ CvrtTmp]                ' send convert temperature command
      DO                                    ' wait on conversion
        PAUSE 25                            ' small loop pad
        OWIN DQ, 4, [tempIn]                ' check status (bit transfer)
      LOOP UNTIL (tempIn)
      OWOUT DQ, 0, [ RdSP]                  ' read DS1822 scratch pad
      OWIN  DQ, 2, [tLo, tHi]               ' get raw temp data
      tSign = sign                          ' save sign bit
      tempC = tempIn >> 4                   ' round to whole degrees
      tempC.BYTE1 = $FF * tSign             ' correct twos complement bits
      tempF = (ABS tempC) * 9 / 5           ' start F conversion
      IF (tSign) THEN                       ' finish F conversion
        tempF = 32 - tempF                  ' C was negative
        tempF = tempF + 32                  ' C was positive
      Panel = tempF
       OWOUT DQ, 1, [ MatchRom,$28,$34,$AF,$5F,$07,$00,$00,$4B]
      LOOP UNTIL (tempIn)
      tank = tempF
    read_serial:
        hserin 1000,timeout,[WAIT (":"),Nb_var22,Nb_var21,Nb_varH23,Nb_varM23,Nb_var24,Nb_varH27,Nb_varM27,Nb_var28,Nb_varH59,Nb_varM59,Nb_var60]
        hserin 1000,timeout,[WAIT (":"),Nb_var31,Nb_var32,Nb_varH33,Nb_varM33,Nb_var34,Nb_varH37,Nb_varM37,Nb_var38,Nb_varH63,Nb_varM63,Nb_var64]
        hserin 1000,timeout,[WAIT (":"),Nb_var41, Nb_var42,Nb_varH43,Nb_varM43,Nb_var44,Nb_varH47,Nb_varM47,Nb_var48,Nb_varH67,Nb_varM67,Nb_var68, hour, minute,Day ] 'get temp setting from Master
    Send_serial:
         hserout [dec tank, dec panel]'send info to Master
         serout2 PortB.4,16468,[1,"got data"]
         pause 2000
    @ INT_RETURN
    timeout:
    RCSTA.4=0
    RCSTA.4=1
    serout2 PortB.4,16468,[1,"error    "]
    pause 2000
    @ INT_RETURN
  1. 18f2525 with LM34
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 04:47
  2. 18F2525 ADC Accuracy
    By mungam753 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2005, 04:48
  3. 18F2525 Stack Pointer
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2005, 13:40
  4. 18F2525 Int Osc settings?
    Last Post: - 26th March 2005, 22:44
  5. Interrupts on 18F2525
    Last Post: - 26th March 2005, 02:37
