Easy way to do multiple write statements ?
Results 1 to 11 of 11
    Default Re: Easy way to do multiple write statements ?
    Richard,
    what is the difference in using EXT ant this one?
    data_blk  var byte [25]
    f_0       var data_blk[7]
    ioannis
    data_blk var byte [25] this reserves 25 bytes for our data
    f_0 var data_blk[7] would definitely point to the correct byte but if you add or delete or rearrange or modify any vars in the array you have to go back and make sure the index is corrected , its easy to make a mistake and forget
    whereas :-
    using
    f_0 var byte ext the assembler does all the work and we still get an index-able byte sized pointer to use
  1. Darrels interrupts and multiple SOUND statements, will it work?
    Last Post: - 26th January 2015, 07:42
  2. Programming multiple pics with multiple programs
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 17:47
  3. Multiple IF THEN Statements: PIC16F84A
    By bob425 in forum mel PIC BASIC Pro
    Last Post: - 10th August 2012, 06:01
  4. SD Multiple Write?
    By jimbostlawrence in forum General
    Last Post: - 21st October 2011, 17:45
  5. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 18:28
