Easy way to do multiple write statements ?
Results 1 to 11 of 11
    Bombay, India
    Default Re: Easy way to do multiple write statements ?
    Assuming that each of the hours and minutes are bytes and PWM value is a word, the write command will fill up 6 bytes on each pass. So, the code would become
       address =$50
       for counterd = 0 to 15
           write (address + (counterD*6)),lightsetHR(counterD),lightsetMN(counterD),lighto ffHR(counterD),lightoffMN(counterD),fadeset(counte rD)
       next counterD
    OR you could also do this
      address =$50
         write (address),lightsetHR(counterD),lightsetMN(counterD),lighto ffHR(counterD),lightoffMN(counterD),fadeset(counte rD)
         address = address+6  ' account for the data already filled into the storage
      next counterD
    Apr 2011
    Welches, Oregon
    You spoke in your original post of an "easier way", while this is not exactly what you asked, I find it easier and so offer...
    Keeping track of hours and minutes separately is unnecessary. For me, over and again, I have determined that a word value representing the minutes since midnight (a value of 0 to 1440) is clearer and easier to manipulate. Switching to hours and minutes is as easy as /60 for hours and MOD 60 for minutes. All calculations loose the clumsiness of handling hours and minutes separately and determining if dates change when subtracting or adding periods is less complicated.
    It doesn't save any actual eeprom space, but it could reduce the typing by changing "lightsetHR(counterD),lightsetMN(counterD)," to SetTime(counterD) and "lightoffHR(counterD),lightoffMN(counterD)," to OnOffTime(counterD)
    ... just a thought.
    Oct 2009
    Quote Originally Posted by Amoque View Post
    ... just a thought.
    I agree and that's the way I do the matching of the if then statements. The code reads the RTC, and the end result is placed in two variables, TimeH and TimeM. Then the TimeH is multiplied by 60 and added to TimeM and placed in a variable Counter1. I then have a similar statement CH1_on_Time = (lightsetHR1*60)+lightsetMN1 to convert the values in the above statement which are then placed in a variable, and then it's a simple matter to do the actions required depending on if the two variables match or one is < or > than other.
    Oh and just to update this thread, and for reference for anyone in the future who may stumble on this thread...
     address =$50
         read (address),lightsetHR(counterD),lightsetMN(counterD),lightoffHR(counterD),lightoffMN(counterD),fadeset.lowbyte(counterD),fadeset.highbyte(counterD)
      next counterD
    With the the matching WRITE command, works a treat - thanks Jerson ;-)
    Oct 2009
       address =$50
       next counterD
      address =$50
      next counterD
    Guys, I need a little help in a similar vein.
    I'm working on a slightly different program using similar variables only this time I save 48 word variables, which results in 96 lines of code for both WRITE and READ statements. The word variables are
    CH1_Max, CH1_on_Time, CH1_off_Time, so I have
    read 40,CH1_on_Time.lowbyte
    read 41,CH1_on_Time.highbyte
    read 42,CH2_on_Time.lowbyte
    read 43,Ch2_on_Time.highbyte
    Rather than have 96 lines of code is there a simple way to do this with a FOR / NEXT loop similar to above
    I did try
    for n = 8 to 38 step 2
    READ n, ch(n)_max.lowbyte
    next n
    for n = 9 to 39 step 2
    READ n, ch(n)_max.highbyte
    next n
    But this just threw up errors when I tried compiling (I'm using PBP 2.60c)
    Any suggestions ?
    the "EXT" modifier make this a breeze , see if you can follow this example
        amps         Var Word   ext    ;chg mA
        volts        Var Word   ext    ;chg V
        kp           var word   ext
        kd           var word   ext
        ki           var word   ext
        f_0        var byte   ext
        f_1        var byte   ext
        f_2        var byte   ext
        f_3        var byte   ext
        setpoint     var word   ext   ;out volts
        cl           var word   ext   ;current limit
        flgs         VAR byte   ext
        drive        var word   ext   ;current pwm value
        a_cal        var word   ext
        v_cal        var word   ext
        bat_r        Var byte   ext    ;bits 0:3 is batt being charged , 4:7  batt connected flg
        data_blk        var byte[26]
    asm
    volts    = _data_blk   ;01
    amps     = _data_blk+2 ;23
    flgs     = _data_blk+4 ;4
    drive    = _data_blk+5 ; 56
    F_0      = _data_blk+7
    F_1      = _data_blk+8
    F_2      = _data_blk+9
    F_3      = _data_blk+10
    setpoint = _data_blk+11 ;1112
    bat_r    = _data_blk+13
    ki       = _data_blk+14 ;1415
    cl       = _data_blk+16
    kp       = _data_blk+18
    kd       = _data_blk+20
    a_cal    = _data_blk+22
    v_cal    = _data_blk+24 ;2425
    endasm
    to save
    for n =0 to 25
    write n, [data_blk[n]]
    next n
    to read
    for n =0 to 25
    read n, [data_blk[n]]
    next n
    to just save vars f_0 to f_3
    for n =7 to 10
    next n
    or even better
    for n =0 to 3
    write n, [f_0[n]]
    next n
    Richard,
    what is the difference in using EXT ant this one?
    data_blk  var byte [25]
    f_0       var data_blk[7]
    ioannis
    data_blk var byte [25] this reserves 25 bytes for our data
    f_0 var data_blk[7] would definitely point to the correct byte but if you add or delete or rearrange or modify any vars in the array you have to go back and make sure the index is corrected , its easy to make a mistake and forget
    whereas :-
    using
    f_0 var byte ext the assembler does all the work and we still get an index-able byte sized pointer to use
  1. Darrels interrupts and multiple SOUND statements, will it work?
    Last Post: - 26th January 2015, 07:42
  2. Programming multiple pics with multiple programs
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 17:47
  3. Multiple IF THEN Statements: PIC16F84A
    By bob425 in forum mel PIC BASIC Pro
    Last Post: - 10th August 2012, 06:01
  4. SD Multiple Write?
    By jimbostlawrence in forum General
    Last Post: - 21st October 2011, 17:45
  5. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 18:28
