PIC Nixie Clock project
Results 1 to 32 of 32
    Oct 2009
    Utah, USA
    Default PIC Nixie Clock project
    Hey Group,
    I am designing an adapter board to allow a 20 pin pic (like a 16F690 or 16F1828, etc) to take the place of an MSP430 processor. Why?? You might ask.
    Well I bought one of these...Name:  clock.jpg
    from here... https://www.tindie.com/products/RobG...xie-clock-kit/ and want to modify the way it works. Unfortunately, for me, it is controlled by an TI MSP430 processor and coded in C.
    The clock is (I believe) an outstanding value as far as nixie clocks go. ($50 usd) which includes the NIXIE tubes and optional case.
    I have actually purchased 2 additional clocks, 3 total. One for my son to build. Then my daughter liked it so much that I told her if she would put it together then I would get her one for Christmas.
    Though the clock is quite a beautiful piece it is lacking in some features that I wanted.
    Self setting time from NTP time source.
    Able to blank the display during certain hours as the clock is in my bedroom and quite bright at night.
    Able to blank the display when not at home to extend life of the nixie's.
    Able to alternately display indoor/outdoor temperature.
    (Add your own feature here...you are the programmer)
    So I designed this... Name:  PCB.jpg
    Based on this schematic...Name:  Schematic.jpg
    Which includes one of these... Name:  ESP01.jpg
    The adapter PCB has a spot for a ds18b20 to provide indoor room temperature.
    There is a couple of extra I/O pins to allow you to remotely recieve outdoor temperature if desired.
    Will be able to get NTP time via the ESP wifi module and auto set the clock and keep accurate time.
    Will have a web interface, also via the ESP, to allow you to choose hours of display on/off and easily change other parameters.
    Includes a PICKIT programming header to allow firmware updates easily.
    And will be coded in our favorite PBP BASIC so it will be easy to customize.
    The little 1.5" x 1.5" board is an adapter that will plug into the socket for the MSP430 and fit nicely inside the case.
    So if you are interested in joining in and having some fun and ending up with a nice little nixie clock... well... stay tuned. Or better yet get your clock on order! (be sure to get the optional case) assuming you want it.
    I am not associated with the maker of the tindie clock kit just a satisfied customer.
    I'd be happy to share my code and you can order your own adapter board from oshpark (3 for $12)
    Here is another link to someones webpage reviewing the clock kit... http://maniacallabs.com/2015/03/11/m...-clock-by-rob/
    I have not yet received the adapter PCB from Oshpark, so at this time it's untested. I'll post back here when I get it and assuming no errors, etc. Here is the link to the adapter board... https://oshpark.com/shared_projects/VGYjILPE
    What do you all think??
    Dwight
    Oct 2009
    Utah, USA
    Default Re: PIC Nixie Clock project
    Hey Group (again),
    I have a pretty decent beta version of the code up and running.
    My clock will now...
    > auto set the time via wifi from the esp module (ntp time source) on initial power up
    and every day at 0500
    > blanks the display between 2200 and 0600
    > cycle through all nixie digits to prevent cathode poisioning (every 15 minutes for 5 sec)
    probably overkill but it looks cool
    > you can choose 12 hr, 24 hr or a mode where the hours alternate between 12/24 hr
    for those who can't read 24 hr time but want to learn
    > can display room temperature (but I haven't actually added this to the code yet)
    here are some pics...
    Name:  2016-02-14 17.08.21.jpg
    Name:  2016-02-14 17.08.47.jpg
    Name:  2016-02-14 17.09.48.jpg
    Name:  2016-02-14 17.10.06.jpg
    Name:  2016-02-14 17.06.23.jpg
    Name:  2016-02-14 17.10.56.jpg
    here is my beta version of the code...
    It runs on an 16F1828 or 16F1829 and with minor mods will run on an 16f690
    '*  Name    : MSP to PIC Nixie clock.BAS                        *              *
    '*  Author  : [Dwight Merkley]                                  *
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 1/2/2016                                          *
        __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
        __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
    #endconfig
    DEFINE OSC 8
    include "ALLDIGITAL.Pbp"
    H10  VAR PortC.0    'hours tens digit enable
    H1   var PortC.1    'hours ones digit enable
    M10  var PortC.2    'minutes tens digit enable
    M1   var PortC.3    'minutes ones digit enable
    symbol PORT_PIN = PORTC  'used to sequentially enable portC.0-3 nixie tubes
    res  var PortC.4    '0-9 digit reset
    clk  var PortC.6    '0-9 digit counter input
    ena  var PortC.7    'ENA on nixie decade counter
    led  var LATC.5     'pwm led backlight
    sw1  var portA.2     'input upper switch
    sw2  var portA.1     'input lower corner switch
    swflg var bit        'bit used to debounce switch pushes
    ts   var portB.4     'OneWire Temperature sensor
    rxE  var portB.5     'input rx data from esp8266
    txE  var portB.7     'tx data to esp8266
    fet  var portB.6     'High Voltage shutdown
    tube var byte       'refrence tube 0-3 [hh h mm m]
    hh   var byte         'variable holding hours
    h12  var byte
    mm   var byte         'variable holding minutes
    ss   var byte         'variable holding seconds
    d1   var byte
    d2   var byte
    d3   var byte
    d4   var byte
    s1   var byte
    s0   var byte
    mode var byte    '12 to 24 hour conversion flag'
    num  var byte    'current digit's pulse count
    x    var byte      'general purpose variable
    y    var byte      'counter to track time between esp serial request output
    dgt  var byte
    temp     var byte   'temporary lcd display data
    IntCnt   var word
    IntFlag  var bit
    dispflag var bit  'flag to indicate if display should be off
    temptime var byte 'var to determine if time to check temperature
    'the following var's are used in the anti-cathode poisoning routine
    position var byte
    numx     var byte
    cath     var byte
    index    var byte
    '-------------[variables and constants for temperature routine]--------------
    DS18B20_9bit  CON %00011111   ' set resolution on DS18B20 93.75ms, 0.5 C
    DQ            VAR   PortB.4   ' One-wire Data-Pin "DQ" on PortB.4
    Busy          VAR BIT         ' Busy Status-Bit
    Raw           VAR   WORD      ' RAW Temperature readings
    TempF         VAR WORD        ' Temp in deg F
    Cold_Bit      VAR Raw.BIT11   ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Sign          VAR BYTE[1]     ' +/- sign for temp display
    TempH         var word        ' var for highest temp
    TempL         var word        ' var for lowest temp
    SignH         var byte[1]
    SignL         var byte[1]
    C             VAR WORD     ' Celsius
    F             VAR WORD     ' Fahrenheit
    INCLUDE  "Temp_Convert.pbp"
        TRISA = %00000110
        TRISB = %00100000
        TRISC = %00000000
        WPUA  = %00000110
      OSCCON  = %01110000   'set internal osc to 8 mhz
    espbaud con 84
    hh = 99
    mm = 00
    ss = 00
    mode = 2    'modes
                '0=24 hour only display
                '1=12 hour only display
                '2=24 hour with alternating 12 hour
                '     for dummies who don't know 24 hour time
    IntCnt = 0
    temp = 0
    ' -----[ Timer setup ]------------------------------
    disable interrupt
    On Interrupt goto MyInt    'define where interrupts should go
    INTCON     = %11000000     'now enable GIE,PEIE,x,x,GPIE,x,x,x
    T1CON =  %00110101 'Enable Timer1 with 1:8 prescaler
    PIE1  =  %00000001 'Enable Timer1 overflow interrupt
    PIE2  =  %00000000
    PIR1.0=0 'clear the timer1 interupt flag
    txe=1     'high the serial output pin, needs to start high
    '========            MAIN                ===========
    Enable Interrupt
    if swflg = 1 and sw1=1 then swflg = 0  '(sw debounce) clear swflg when switch released
    if swflg = 0 and sw1=0 then
        swflg = 1
        if mode = 0 then
            mode = 1  'switch to 12 hr mode
            goto SkipSw
        if mode = 1 then
            mode = 2  'switch to 24 hrr mode with 12 hr flash
            goto SkipSw
        if mode = 2 then
            mode = 0  'switch to 24 hr mode
    SkipSw:
    'an interrupt is generated every .005 sec
    'so clear the IntFlag and cycle to the next nixie tube
    if  IntFlag=1 then
        IntFlag=0
        IntCnt = IntCnt + 1
        gosub Tubes
    if  IntCnt > 199 then gosub NextSec 'time to increment seconds
    'this next routine fires every 15 minutes between 55 and 58 seconds
    'it causes all digits in each nixie to be cycled to prevent
    'cathode poisioning
    if mm//15=0 and (ss >54 and ss<58) then
        if intcnt//10 = 0 then gosub NixieBurn
    'this routine blanks the display between 2200 and 0600
    if (hh>21) or (hh<6) then 'turn display off between 2200 and 0600
        dispflag = 0
        dispflag = 1
    'this routine only runs on startup and waits for 30 sec
    'then it goes and reads the time from the ESP module
    if hh = 99 then
        d1=s0
        d2=s1
        dispflag = 1
        if ss=30 then gosub GetTime
    'this routine sets the clock once a day at 0500
    if hh=5 and mm=0 and ss=0 then gosub GetTime
    toggle led   'for backlight brigtness at 50%
                 ' use O-Scope to determine Main loop timing
    goto Main
    '  interrupt every 5 msec
    disable interrupt
    MyInt:
        IntFlag=1    ' INT has fired so set this flag for Main code usage
        '>H & L size determine INT timing, INT every .005 seconds
        TMR1H = $FB  ' reset timer1h
        TMR1L = $1F  ' reset timer1l
        PIR1.0 = 0   ' clear timer1 overflow flag
    resume    'to Main
    enable interrupt
    '          increment seconds and trickle down time
    NextSec:
    intCnt = 0
    ss = ss +1
    if  ss = 60 then
        ss = 00
        mm = mm + 1
    if  mm = 60 then
        mm = 0
        hh = hh + 1
    if  hh = 24 then
        hh = 0
    if hh>12 then
        h12=hh-12
        h12=hh
    d1=mm//10
    d2=mm/10
    d3=hh//10
    d4=hh/10
    s1=ss/10
    s0=ss//10
    if mode=1 then      '12 hr only mode
        d3=h12//10
        d4=h12/10
    'this routine causes the display to alternate between 24 and 12 hr display
    if mode = 2 and (s0=0 or s0=5) then  '24 hr mode with
       d3=h12//10                        '12 hr overlay at 0 & 5 sec
       d4=h12/10
    '--- Routine to cycle all digits on all tubes  ---
    '--- to prevent cathode poisoning (look it up) ---
    NixieBurn:
    numx=numx+1
    if numx=10 then numx=0
    for position=0 to 3
        index=numx+position
        if index>9 then
           index=index-10
        lookup2 index,[1,6,2,7,5,0,4,9,8,3],cath
        if position = 0 then d1=cath
        if position = 1 then d2=cath
        if position = 2 then d3=cath
        if position = 3 then d4=cath
    next position
    '          display next NIXIE digit
    Tubes:
    PORT_PIN.0[tube] = 0        'Turn OFF the current tube
    if dispflag = 0 then
        led = 1
        return                  'display is off so skip tubes
    tube=tube + 1
    if tube > 3  then tube = 0
    Digit:
        high res                'reset the decade counter
    @   nop
        low res                 'release the reset
    lookup2 tube,[d4,d3,d2,d1],num
    for x = 1 to num            'pulse the clock for "num" counts
        high clk
    @   nop
        low clk
    next x
        PORT_PIN.0[tube] = 1    'Turn ON the next tube
    '          Get TIME from ESP8266-01 NTP Time Server
    Disable Interrupt
    SerTmout:
        led=0
        pause 200
        led=1
        pause 200
        led=0
        pause 200
        led=1
        pause 200
    GetTime:
                ' Wait for >,CR,LF from ESP module
        serin2  rxe,espbaud,3000,SerTmout,[wait(">"),wait(13),wait(10)]
                ' ESP module expects "Time?" before it will give hhmmss
                ' to change this modify the ESP code
        serout2 txe,espbaud,["Time?"]
        serin2 rxe,espbaud,3000,SerTmout,[dec2 hh,dec2 mm, dec2 ss]
                ' set NIXIE tube positions for their
                ' respective h h m m, d4,d3,d2,d1
        d4=hh/10
        d3=hh//10
        d2=mm/10
        d1=mm//10
        s1=ss/10  ' s0 & s1 only gets used when displaying seconds
        s0=ss//10 ' untill time retreval from ESP module at 30 sec
    Enable Interrupt
    '           Read Temp Sensor and convert to deg F
    disable interrupt
    GetTemp:
        OWOUT  DQ,%001,[$CC, $4E, 0, 0, DS18B20_9bit]  'set resolution of sensor
    Start_Convert:
        OWOUT  DQ,%001,[$CC, $44]           ' Skip ROM search & do temp conversion
    Wait_Convert:
        OWIN   DQ,%100,[Busy]               ' Read busy-bit
        IF     Busy = 0 THEN Wait_Convert   ' Still busy..?, Wait_Convert..!
        OWOUT  DQ,%001,[$CC, $BE]           ' Skip ROM search & read scratchpad memory
        OWIN   DQ,%010,[Raw.byte0, Raw.byte1]' Read two bytes / end comms
        '--------------  Convert_Temp: -----------------------
        Sign="+"
        IF Cold_Bit = 1 THEN                'it's below zero Celsius
          C=(ABS Raw>>4)*-10                'so shift the ABS value right and mult X -10
          C=(Raw>>4)*10                     'else shift value right and mult X 10
    @   CtoF _C, _F            ; Convert Celsius to Fahrenheit
            'converted value will be X 10, ie. 756=75.6 deg F
            'so devide by 10 to get whole degrees
        IF f.15=1 THEN Sign="-"         'if converted value is below zero F then sign is "-"
        TempF = (ABS f)/10              'take tha ABS value and /10
        IF f//10 >4 THEN TempF=TempF+1  'check remainder, if >4 then round up
    return                              'with TempF containing current temperature
    enable interrupt
    and here is the code that runs on the ESP8266-01 module
    memclear
    cls
    timesetup(-7,0)
    baudrate 9600
    serialtimeout 2000
    delay 1000
    button "Exit " [Exit]
    [Main]
    timer 100 [PicSer]
    wait
    [PicSer]
    serialflush
    input picIN
    picIN = mid(picIN,1,5)
    if picIN == "Time?" then gosub [gettime]
    wait
    [gettime]
    bla = time()
    hh = mid(bla,12,2) 'hour
    mm = mid(bla,15,2) 'min
    ss = mid(bla,18,2) 'sec
    picOUT = hh & mm
    picOUT = picOUT & ss
    serialprint picOUT
    [Exit]
    this has been fun and a real challenge
    IF anyone would like to build one let me know and I'd be glad to help you out with parts procurement, etc for the little adapter board.
    Dwight
    Oct 2009
    Utah, USA
    My latest working version of the code is posted below.
    It incorporates Darrell Taylor's Instant Interrupts modified by Tabsoft in this thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=19910
    It incorporates a check for USA Daylight Saving Time
    I currently have commented out the temperature sensor code as I have not decided how/or if I am going to implement a temperature display.
    enjoy
    dwight
    '*  Name    : Nixie_DST_InstantInt.BAS                          *
    '*  Author  : [Dwight Merkley, N7KBC]                           *
    '*  Notice  : Copyright (c) 2016                                *
    '*  Date    : 3/10/2016                                         *
    '*  Notes   : 16F1828                                           *
    #endconfig
    ;--   Copied from DT_INTS-14 as per instruction in DT_INTS-14  -------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    define  OSC 8
    include "DT_INTS-14.bas"            'Needs to be in same PBP folder as PBPW.EXE
    include "ReEnterPBP.bas"            'Needs to be in same PBP folder as PBPW.EXE
    include "ElapTimer_5ms_Interrupt.pbp"   'Needs to be in same PBP folder as PBPW.EXE
    swflg1 var bit        'bit used to debounce switch pushes
    swflg2 var bit        'bit used to debounce switch pushes
    'hh   var byte         'variable holding hours
    h12  var byte
    'mm   var byte         'variable holding minutes
    'ss   var byte         'variable holding seconds
    d1   var byte
    d2   var byte
    d3   var byte
    d4   var byte
    s1   var byte
    s0   var byte
    dow var byte       'sun = 0, sat = 6
    mth var byte       'Jan = 01 ... Dec = 12
    date var byte      'numerical day of month
    dst var bit
    dgt  var byte
    IntCnt   var word
    IntFlag  var bit
    posx var byte
    numx     var byte
    cath     var byte
    index    var byte
    CatCnt  var word
    CC  var bit
    ''DS18B20_9bit  CON %00011111   ' set resolution on DS18B20 93.75ms, 0.5 C
    ''DQ            VAR   PortB.4   ' One-wire Data-Pin "DQ" on PortB.4
    ''Busy          VAR BIT         ' Busy Status-Bit
    ''Raw           VAR   WORD      ' RAW Temperature readings
    ''TempF         VAR WORD        ' Temp in deg F
    ''Cold_Bit      VAR Raw.BIT11   ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    ''Sign          VAR BYTE[1]     ' +/- sign for temp display
    ''TempH         var word        ' var for highest temp
    ''TempL         var word        ' var for lowest temp
    ''SignH         var byte[1]
    ''SignL         var byte[1]
    ''C             VAR WORD     ' Celsius
    ''F             VAR WORD     ' Fahrenheit
    ''INCLUDE  "Temp_Convert.pbp"
        TRISA = %00000110
        TRISB = %00100000
        TRISC = %00000000
        WPUA  = %00000110
    espbaud con 84
    Hours = 99
    Minutes = 00
    Seconds = 00
    mode = 2    'modes
    swflg1=0    'flag used to debounce sw1 press
    swflg2=0    'flag used to debounce sw1 press
    CC = 0
    numx=0
    IntCnt = 1
    temp = 0
    ' Define and Create the Instant Interrupt for Timer1
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
        INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    Gosub ResetTime           ' Reset Time to  0d-00:00:00.000
    Gosub StartTimer          ' Start the Elapsed Timer
    Hours = 99
        if swflg1 = 1 and sw1=1 then swflg1 = 0  '(sw debounce) clear swflg when switch released
        if swflg1 = 0 and sw1=0 then   'sw1 button detected
            swflg1 = 1
            mode=mode+1
            if mode = 3 then mode = 0
        if sw2=0 then gosub gettime  'sw2 button detected
        if  MSecsChanged = 1 then
            MSecsChanged = 0
            catcnt = catcnt + 1
            gosub Tubes
        iF SecondsChanged = 1 then
           SecondsChanged = 0
           gosub NextSec
            'this next routine fires every 15 minutes between 4 and 7 seconds
            'cathode poisioning
        if (Hours !=99 and Minutes//15=0) and (Seconds >4 and Seconds<11) then
           cc=1
           cc=0
        if catcnt>19 and cc=1 then gosub CatClean
        if cc=0 then catcnt=0
        'this next routine blanks the display between 2200 and 0600
        if (Hours>21) or (Hours<6) then 'turn display off between 2200 and 0600
            dispflag = 0
            led=1   'turn off the LED backlight
            dispflag = 1
        if  Hours = 99 then
            d1=Seconds//10
            d2=Seconds/10
            d3=0
            d4=0
            dispflag = 1
            if Seconds=40 then gosub GetTime
        if Hours=5 and Minutes=0 and Seconds=0 then gosub GetTime
        if dispflag =1 then toggle led   'for backlight brigtness at 50%
                     ' can use O-Scope to determine Main loop timing
    goto Main
    NextSec:
        if cc=1 then SkipSec
        gosub dstcalc
        if  Hours > 12 then
            h12=Hours - 12
            h12 = Hours
        d1=Minutes//10
        d2=Minutes/10
        d3=Hours//10
        d4=Hours/10
        s1=Seconds/10
        s0=Seconds//10
           d3=h12//10
           d4=h12/10
           d4=h12/10
    SkipSec:
    CatClean:
        catcnt=0
        if Hours=99 then
            d1=Minutes//10
            d2=Minutes/10
            goto SkipClean
        numx=numx + 1
        if numx >9 then numx=0
        for posx=0 to 3
            index = numx + posx
            lookup index,[1,6,2,7,5,0,4,9,8,3,1,6,2,7,5,0,4,9,8,3],cath
            if posx = 0 then d1=cath
            if posx = 1 then d2=cath
            if posx = 2 then d3=cath
            if posx = 3 then d4=cath
        next posx
    SkipClean:
    Tubes:
        if dispflag = 0 then Skipdisp
        tube=tube + 1
    Digit:
    @   nop
            high clk
    @       nop
            low clk
        next x
    SkipDisp:
    SerTmout:
        led=0
        pause 200
        led=1
        pause 200
        led=0
        pause 200
        led=1
        pause 200
    GetTime:
    @   INT_DISABLE  TMR1_INT  ; Disable Timer 1 Interrupts
        serin2  rxe,espbaud,2000,SerTmout,[wait(">"),wait(13),wait(10)]
        serin2 rxe,espbaud,3000,SerTmout,_
            [dec1 dow,wait("/"),dec2 mth,wait("/"),dec2 date,wait("/"),_
             dec2 Hours,dec2 Minutes,dec2 Seconds]
    gosub dstcalc       'check to see if DST is in effect
    if dst=1 then Hours = Hours + 1
    if Hours = 24 then Hours = 00
        d4=Hours/10
        d3=Hours//10
        d2=Minutes/10
        d1=Minutes//10
        s1=Seconds/10  ' s0 & s1 only gets used when displaying seconds
        s0=Seconds//10 ' untill time retreval from ESP module at 30 sec
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    ''GetTemp:
    ''    PORT_PIN.0[tube] = 0   'Turn OFF the current tube
    ''    OWOUT  DQ,%001,[$CC, $4E, 0, 0, DS18B20_9bit]  'set resolution of sensor
    ''Start_Convert:
    ''    OWOUT  DQ,%001,[$CC, $44]           ' Skip ROM search & do temp conversion
    ''Wait_Convert:
    ''    OWIN   DQ,%100,[Busy]               ' Read busy-bit
    ''    IF     Busy = 0 THEN Wait_Convert   ' Still busy..?, Wait_Convert..!
    ''    OWOUT  DQ,%001,[$CC, $BE]           ' Skip ROM search & read scratchpad memory
    ''    OWIN   DQ,%010,[Raw.byte0, Raw.byte1]' Read two bytes / end comms
    ''    '--------------  Convert_Temp: -----------------------
    ''    Sign="+"
    ''    IF Cold_Bit = 1 THEN                'it's below zero Celsius
    ''      C=(ABS Raw>>4)*-10                'so shift the ABS value right and mult X -10
    ''      ELSE
    ''      C=(Raw>>4)*10                     'else shift value right and mult X 10
    ''    ENDIF
    ''@   CtoF _C, _F            ; Convert Celsius to Fahrenheit
    ''        'converted value will be X 10, ie. 756=75.6 deg F
    ''        'so devide by 10 to get whole degrees
    ''    IF f.15=1 THEN Sign="-"         'if converted value is below zero F then sign is "-"
    ''    TempF = (ABS f)/10              'take tha ABS value and /10
    ''    IF f//10 >4 THEN TempF=TempF+1  'check remainder, if >4 then round up
    ''    PIR1.0 = 0                  ' clear timer1 overflow flag
    ''return                              'with TempF containing current temperature
    '---  DST Calc (dec1 dow,dec2 mth,dec2 date)  ---
    dstcalc:
    '    if dayschanged = 1 then
    '       dayschanged = 0
    '       dow = dow+1
    '       if dow >7 then dow=0
    '    endif
    dst = 1      'covers Apr, May, Jun, Jul, Aug, Sep, Oct
    If mth=01 then dst = 0  'Jan
    If mth=02 then dst = 0  'Feb
    If mth=12 then dst = 0  'Dec
    March:
    if mth=03 then                                       'March
        if  date <8 then
            dst=0
            elseif (date>7 and date<15) and dow=1 and hours<2 then
            dst=0
            elseif (date=8  and dow>1) then
            dst=0
            elseif (date=9  and dow>2) then
            dst=0
            elseif (date=10 and dow>3) then
            dst=0
            elseif (date=11 and dow>4) then
            dst=0
            elseif (date=12 and dow>5) then
            dst=0
            elseif (date=13 and dow>6) then
            dst=0
    November:
    if  mth=11 then                                  'November
        if  date >7 then
            dst=0
            elseif (date <8 and dow=1) and hours>1  then
            dst=0
            elseif (date=2 and dow<3) then
            dst=0
            elseif (date=3 and dow<4) then
            dst=0
            elseif (date=4 and dow<5) then
            dst=0
            elseif (date=5 and dow<6) then
            dst=0
            elseif (date=6 and dow<7) then
            dst=0
    '---  This is the code running on the ESP8266-01 module  ---
    '''memclear
    '''cls
    '''timesetup(-7,0)
    '''baudrate 9600
    '''serialtimeout 2000
    '''delay 1000
    '''button "Exit" [Exit]
    '''timer 100 [PicSer]
    '''wait
    '''[PicSer]
    '''serialflush
    '''input picin
    '''picin = mid(picin,1,5)
    '''if picin == "Time?" then gosub [gettime]
    '''wait
    '''[gettime]
    '''bla = time()
    '''dy = mid(bla,1,3)  'dow
    '''mh = mid(bla,5,3)  'month
    '''dd = mid(bla,9,2)  'date
    '''hh = mid(bla,12,2) 'hour
    '''mm = mid(bla,15,2) 'min
    '''ss = mid(bla,18,2) 'sec
    '''yr = mid(bla,21,4) 'year
    '''if dy == "Sun" then dow = "1/"
    '''if dy == "Mon" then dow = "2/"
    '''if dy == "Tue" then dow = "3/"
    '''if dy == "Wed" then dow = "4/"
    '''if dy == "Thu" then dow = "5/"
    '''if dy == "Fri" then dow = "6/"
    '''if dy == "Sat" then dow = "7/"
    '''if mh == "Jan" then mth = "01/"
    '''if mh == "Feb" then mth = "02/"
    '''if mh == "Mar" then mth = "03/"
    '''if mh == "Apr" then mth = "04/"
    '''if mh == "May" then mth = "05/"
    '''if mh == "Jun" then mth = "06/"
    '''if mh == "Jul" then mth = "07/"
    '''if mh == "Aug" then mth = "08/"
    '''if mh == "Sep" then mth = "09/"
    '''if mh == "Oct" then mth = "10/"
    '''if mh == "Nov" then mth = "11/"
    '''if mh == "Dec" then mth = "12/"
    '''picout = dow & mth
    '''picout = picout & dd
    '''picout = picout & "/"
    '''picout = picout & hh
    '''picout = picout & mm
    '''picout = picout & ss
    '''serialprintln picout
    '''return
    '''[Exit]
    '''end
    Dwight
    Oct 2009
    Utah, USA
    I forgot to mention that the new enhanced code that needs to be loaded on the ESP module is located at the bottom of the above posted PIC listing. It is commented out so it doesn't interfere with the PIC code.
    This new ESP code provides more NTP time data to the PIC. It now sends day of week, month and day of month, along with the HH:MM:SS
    The pic code used the date information to determine if daylight saving time needs to be in effect.
    Due to drift in the internal osc in the 16f1828 you may want to check NTP time more than once a day.
    It seems to drift about 2 minutes in 24 hours so checking the time 2-3 times a day (or even once an hour) would insure your clock is more accurate.
    cheers
    dwight
    PS if you decide to build one of these please let me know before you order your boards from oshpark as I would be willing to upload a new board design that incorporates a couple of improvements. The boards work fine as is but I found that I overdesigned it to try and turn off the high voltage to blank the display and it is much easier to do that in software by just not turning on any digits.
    Dwight
    Well done Dwight!
    A very interesting project, combining old tech with the latest IoT.
    Oct 2009
    Utah, USA
    Thanks Ioannis!!
    It really is a good looking clock and nice to look at sitting on the book shelf.
    And the fact that it sets itself and I can modify the code to my hearts content is all the better.
    My wife commented that she missed it while I was developing the code.
    It really is, in my opinion, a good value for the $50 USD including the case.
    Dwight
    Dwight, I took your DST segment from the PIC code and incorporated it into the ESP8266-01. I am running the version 3.0 ESPBASIC on the ESP8266 and it works flawlessly. I have incorporated it into my version of the Nixie Clock build. I made a few and gave the kits to 2 of my kids for Xmas. Attached are the pics and ESP code.
    EN82fn
    Oct 2009
    Utah, USA
    That's awesome Dave!!
    I am glad you could use the code. It was fun (mental challenge) to figure out how to determine DST.
    Although I did notice that this past Nov my clock did not change to Std Time until the day after it should have (as I recall) I was busy at the time and did not (have not) investigated why. I still need to look into the code and see if I missed something by a day. It did get it right the next day so I did not get too concerned.
    I chose to do all the DST calcs in my PIC code as I am much more familiar with PIC BASIC. But the espBASIC has come a long way since then. I am still running version 1.65 on my esp module so I'll have to update the code to be compatible with the newer 3.xx versions.
    It is amazing how powerful the little esp-01 modules are!!
    73
    dwight
    N7KBC
    Dwight
    Aug 2003
    Hi, Nice idea to get rid of the chip that you don’t want and replace with your own board
    If the ESP module getting the time, then the DT elapsed timer is really just cycling through the tubes?
    On EEVblog, a YouTube channel if you watch it, Dave is in the middle of a nixie project now I’ve been watching.
    Oct 2009
    Utah, USA
    Hi Dave,
    go check out the thread over on espbasic... http://www.esp8266.com/viewtopic.php?f=41&t=11518
    and check out his code... he does a better job (simpler code) of determining DST yes/no for the ESP8266
    Note: the following bit of code is not PICBASIC it's espBASIC
    [calculate_DST]
    dow = time("dow")
    day = time("day")
    month = time("month")
    hour = time("hour")
    if ((DST = 1) and (dow = "Sun") and (month = "Nov") and (day >= 1) and (day < 8)) then
     DST = 0
     write(DaylightSavings,str(DST))
    if ((DST = 0) and (dow = "Sun") and (month = "Mar") and (day >=8) and (day < 15)) then
     DST = 1
    and to others... if you haven't checked out and played with mike's awesome espBASIC you are missing out
    esp8266basic.com
    regards
    dwight
    Dwight
    Oct 2009
    Utah, USA
    Here is the webpage that his code creates for the analog meter clock...
    cheers
    dwight
    Dwight
    Mar 2020
    I know this is an old-ish thread, so being a little late to the game I'm hoping I can re-ignite the conversation here.
    I came across this thread whilst searching for some way to automate the time setting of this clock. Great Job! This is a very interesting addition to this already really great Nixie clock.
    Dwight, I'd be interested in the offer of support for helping to procure parts and the newer board design if that's still something you're willing to help with?
    TIA
    I have complete Nixie clock project, written in Picbasic pro, you can find it on instructables "Mid century modern nixie clock". I've updated it to DS3231, added alarm and some other functions (updated code not yet uploaded to instructables), so if anyone can help with hooking ESP to it, I'd be very glad.
    Oct 2009
    Utah, USA
    Hi Curious One,
    WOW! that clock on Instructables is an absolute work of art! I'm jealous.
    So what do you need help with as far as connecting an ESP8266??
    If you look at the beginning of this thread you will find the schematic and code for both the esp module and the PIC.
    (Although today, I would highly recommend you use ANNEX RDS as the language for the esp module so you would need to change my espBASIC code.)
    I'd be happy to help you with that code when you are ready.
    It really is just as simple as setting up a serial comm channel between the PIC and the esp module.
    I'd suggest, if you haven't already, that you join the ANNEX RDS group found here...
    https://sites.google.com/site/annexwifi/home
    where you will find a load of information on the ANNEX operating system. (it is very similar to the older espBASIC but much more advanced and development is very active)
    how can I help?
    dwight
    Dwight
    Oct 2009
    Utah, USA
    MrTeaTime,
    Do you have the same nixie clock as shown in the original post in this thread?
    If so then it is an easy conversion.
    So the boards are available to order on OSHPARK here...
    https://oshpark.com/shared_projects/7fvrYPyd
    you would only need a few extra parts to complete the project.
    what can I help you with?
    dwight
    Dwight
    Thanks for reply.
    There issues are as follows - I'm not a stellar in programing, all what I know is 80s style BASIC and unfortunately have no time or type of mind to learn C++ or some other things. Regarding the ESPbasic, I downloaded it, but was not able to run even a line of code, because it does nothing in browser.
    Regarding hooking the ESP to picbasic, in my clock code I have routine getting time from DS3231. So if anyone can help with same routine but for ESP, that would be cool. Also, by my understanding, ESP is not just plug and go type thing. I mean, if I even add it to my code, say I gave complete clock to friend, he'll need to connect to ESP wifi, to make it work with his access point, manually assign NNTP server and so on. Right? From my point of understanding, GPS or DCF77 looks maybe more complicated, but much more straightforward and easy to use.
    Well, GPS needs clear sky and DCF77 is not available everywhere. I am in Greece and do not receive it or at least not all hours of a day. Maybe if I relocate to a more open area with big antenna... That is not practical...
    I am very interested in ways to use ESP to PBP projects. Have never used that little modules and am a bit afraid to touch them without a step-by-step tutorial. Especially on uploading new firmware and connecting to router and internet.
    get a few wemos d1 minis, a copy of arduino ide
    start here
    https://tttapa.github.io/ESP8266/Cha...20ESP8266.html
    you may never use a pic again
    Incredible link Richard! Thanks a ton for that link. Exactly what a beginner needs.
    Currently I have a couple of the attached modules. Are these any good for experimenting?
Size:  58.5 KBName:  IMG_6124.JPG
    yes , the software is the same for any of them ,inc esp8285
    you just need to chk the pinouts
    Nice. Have homework to do...!
    Thanks again,
    once you go nuts putting web interfaces on your projects you look at a lcd or a tft screen and
    say why bother with that limited old junk, all this on one nodemu 12f
Size:  72.6 KB Name:  sonoffs.jpg
    It is my wish but don't feel very confident right now...
    Exciting on your images you posted! I want it!
    the link i posted got me to this point along with google
    i'm no html expert and my code probably tortures things but who cares it works.
    Mar 2020
    Post Re: PIC Nixie Clock project
    MrTeaTime,
    dwight
    Thanks for the response and the link to the board.
    Just to give you the background, I'm completely new to this, so please forgive the very newbie questions that are bound to come.
    I got the clock from RobG pre-assembled when I was last over in the states about 1.5 years ago, and would certainly class myself as a novice at electronics and I've never touched anything related to espbasic. Saying that, I do come from a software background so am more than happy to give this mod a go
    Having done some research on programming PIC devices, I've been looking at PICKit which I think I'll need to get the chip flashed? In terms of the other components that are required to complete the build, I'd really appreciate if you could list out what they are? I know you included you schematic digram in the original posts, but like I said, I'm very new to this so would appreicate the basics.
    Also, in regards to the wifi chip (ESP01), was there anything that needed to be done to that? I see they come prebuilt, but do they just work?
    Looking forward to getting my head into this some more!
    Thanks in advance
    All that is of course somehow good, but not exactly what is needed for PIC Nixie clock. It's like someone was asking about how to use transistor, but he'd being taught first what is Epitaxy, Czochralski method or Gallium nitride doping. We don't need that.
    All what we need for clock is something like this:
    1. flash this firmware.hex into ESP
    2. Connect it's pin #4 (or whatever), to your PIC port X
    3. Use SERIN X,Y,Z statement to get the current time
    That's all.
    I am afraid it is not that simple. You have to write that firmware.hex and then upload it to the ESP.
    In what IDE you will do this? In Arduino C or Annex Basic?
    If it is going to be #4 or #7 it is up to you. I mean what you did in the previous step.
    The serin is the easy part...
    if you need an esp8266 time server
    https://forum.arduino.cc/index.php?t...004#msg4276004
    could not get much easier , dst timezone the lot. with serial output in various formats
    with explanations
    tz explained here
    https://github.com/G6EJD/ESP32-Time-...ster/README.md
    Yes, need firmware which just delivers time.
    Oct 2009
    Utah, USA
    Hi CuriousOne,
    So to help you get a simple time server up and running on an ESP8266 I have a few questions...
    What are your size constraints?
    Do you have 3.3v available or just 5v?
    If you would be willing to use a larger module like one of these...
    https://www.aliexpress.com/wholesale...=lolin+esp8266.
    my favorite is this one...
    https://www.aliexpress.com/item/3272...archweb201603_
    But it really does not matter too much which module you choose.
    You also note that you have experience with old school BASIC.
    I will tell you it is trivial to flash ANNEX RDS onto one of these modules and then code development is drop dead simple.
    The IDE (Integrated Development Environment) is hosted right on the module.
    You only need a micro USB cable to flash ANNEX and then you simply log onto the webpage of the module and you are in the IDE.
    If you get this far I'd be happy to help you get the few (and I do mean few like <20) lines of code up and running.
    Annex makes it very easy to set your time zone and it handles DST/ST for you.
    You would be able to have the module send you serial time out to one of the pins and have your PIC recieve that time.
    It really is that simple!
    Now there are certainly other ways of doing this (like the arduino environment and C-like code) but this Annex is amazing and very easy!
    Oh yeah... and it is very similar to PIC basic and old school basic from the 80's
    But do not think for a moment it is not powerful.
    It is actively developed and very powerful.
    So do you have any ESP8266 modules on hand??
    If you need the small size of the ESP-01 module then it is just a bit more complex.
    Where the other modules have an onboard USB serial channel for flashing, the ESP-01 does not.
    Therefore you would need an USB-serial cable to flash Annex (or any other OS like Arduino).
    Also the ESP-01 does not have an 5v to 3.3 regulator so you have to feed it with 3.3.
    So if you have a bit more room the larger modules are the way to go.
    Let me know what you have or need.
    Join the discussion over on the ANNEX RDS home page and forum.
    Dwight
    Dwight
    Oct 2009
    Utah, USA
    To anyone who wants to try ANNEX there are several tutorials over on the home page here...
    Id be more than happy to get on a SKYPE to help you get familiar with how to flash annex or understand the features of the IDE.
    Just drop me a direct message through the forum.
    dwight
    Dwight
    For the ESP, I bought them all - big, small, nodemcu or whatever are available.
    I even flashed some wifi clock project, but using LED matrix displays and it works fine, but that does not helps me.
    I can get 3.3 or 5 volt or whatever is needed, that is not a problem.
  1. Color GLCD Project, Analog clock
    By DaveC3 in forum Code Examples
    Last Post: - 14th May 2011, 04:24
  2. pic16f887 clock project, need help
    By lockjawz in forum mel PIC BASIC Pro
    Last Post: - 13th April 2011, 12:45
  3. Digital clock project
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 27th February 2009, 04:00
  4. Help with PIC project
    By davekav in forum General
    Last Post: - 18th April 2008, 00:15
  5. pic project help
    By dizzy1 in forum General
    Last Post: - 5th February 2006, 19:30
Members who have read this thread : 4
