OT - MOSFET choice
Results 1 to 11 of 11
    Oct 2009
    Default OT - MOSFET choice
    Guys, I'm working on a project that uses a PCA9865 PWM chip, and ideally would like to drive a MOSFET (N channel) directly from the pins. The datasheet (if I've read it correctly) states that it can source 5v at 10mA, and I believe that it's possible to get TTL logic MOSFET's that permit the direct connection, and when browsing RS for suitable MOSFETs, get confused with all the other data in the datasheet.
    I'm looking at switching 12-15v dc, up to 3A from each channel, and ideally would like the MOSFET to run cool without heatsinks. Can anyone suggest some suitable devices. P would prefer through hole rather than SOIC surface mount at this stage, but might need to go SOIC later if this project gets enough interest in the future.
    Dec 2007
    Finland
    Default Re: OT - MOSFET choice
    There are couple of parameters that you should look.
    1) Rdcon. This parameter tells how much energy will be burned in device while FET is conducting current. Low is better and range of 10-20mOhm parts are quite inexpensive.
    2) Vdss is enough high. Well above your working voltages
    3) Id @ Vgs=5V is high enough. FET conduct current at used source voltage.
    I don't know how small FET you are looking for but here is one example from RS catalog
    IRFSL3806PBF
    Oct 2009
    Thank you for the explanation, and the link. At that price it's worth getting a pack and testing them on the breadboard
    Cheers
    In switching applications there are more to it than just the Rds-on.
    The gate of the MOSFET looks like a capacitor to the circuit driving it. To turn the MOSFET on you need to "charge" the gate. The longer it takes to charge the gate the more switching loss you'll have, the MOSFET is in the linear region for a longer period of time.
    To charge the gate quickly you want a MOSFET with low gate charge and/or a driver that can charge/discharge it quickly - that is pump current into and out of the gate. You're limitied to 10mA current at 5V which really isn't much in the scheme of things.
    If you want it efficient, don't use a PWM frequency higher than needed and look for a MOSFET with low gate charge (small "capacitor"). Usually, the "larger" the MOSFET is the higher the gate charge is so don't use a 100A MOSFET for a 3A load just because the 100A one has 5mOhm less Rds-on.
    Oct 2009
    I have knocked up an output circuit that works, but may not be ideal. All I had in the way of MOSFETs in my component box was an IRF3708.
    I've used a BC639 to drive the FET using the attached schematic. I've tested this with a six bulb 1/12th chandelier which drew just over 310ma, and a twenty-one bulb light that drew 1100mA and it worked really well... OK the additional 16 transistors and 48 resistors is not much to accommodate in the design, but it would be better for a single component.
    As each channel could end up driving 60 x 50mA bulbs, I've rated rated the device at 3 to 4 amps, but as most of these MOSFETs seem to be rated at 30Amp - 600A or more I don't think I'm going to be taxing them too much. Is it worth looking at these multi-fet devices in SOIC / DIP packages, or would they need cooling ? That TO 292 package that Gusse linked to looks an alternative if no DIP device is suitable.
    Dec 2007
    Finland
    Hi Scampy,
    Based on IRF3708 datasheet, Rdson = 9.5mOhm (typ), Vgs= 4.5V, Id= 12A, therefore PCA9865 should be OK to drive FET without pre-driver stage. Gate resistor might need fine tuning. Ten(s) of ohm might be OK. Resistance on gate and gate input capacitance (~2-3nF), will make a RC-filter.
    Gate capacitance is important parameter as Henrik stated. I didn't include it to my previous post due to fact that PCA9865 max output frequency is low (1526Hz).
    IRF3708 applications are high freq DCDC (~3-6MHz switching freq), so there is no need to worry about that parameter too much.
    With multi-FET packages it is more important to keep Rdson low if all FETs are on same time. It doesn't matter if it is through hole or surface mounted device, same rules applies.
    Reserve enough PCB area for GND under the FET to do proper cooling.
  1. Another ethernet shield choice
    By dhouston in forum PBP & Amicus18
    Last Post: - 11th June 2011, 20:29
  2. Best choice for detecting water?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 21:18
  3. What is right choice?
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 19:14
  4. help wanted on PIC choice
    By Dj tempo in forum General
    Last Post: - 2nd July 2007, 19:05
  5. Correct capacitor choice - OT
    Last Post: - 21st May 2006, 09:49
