2Mhz oscillator not allowed?
Results 1 to 2 of 2
    Nov 2008
    Default 2Mhz oscillator not allowed?
    Like the subject says, does PBP3 not allow for 2Mhz oscillator speeds? I found one post from 2006 claiming this. I have a 16F722A set for 2Mhz but trying to compile anything gives this error
    Error[101]   C:\PBP3\PBPPIC14.LIB 104 : ERROR: (Invalid OSC Define.)
    Error[113]   C:\PBP3\PBPPIC14.LIB 6350 : Symbol not previously defined (PAUSEUSL)
    Default Re: 2Mhz oscillator not allowed?
    I'll just quote the manual:
    There are a limited number of valid numbers that can be used: 3 (3.58MHz), 4, 8, 10, 12, 16, 20, 24, 25, 32, 33, 40, 48, 64. These are the only frequencies for which PBP is able to accurately calibrate its timing. If you use a system clock that runs at a frequency that isn't listed here, your timing will be scaled when the program executes.
    That's pretty clear to me.
  1. Trying to generate 2MHz PWM with PIC18F25K22
    By TimHeff in forum mel PIC BASIC Pro
    Last Post: - 16th July 2012, 05:08
  2. How many volts/amps are allowed outside?
    Last Post: - 26th April 2009, 22:47
  3. Using PIC16F88 oscillator as oscillator for other ICs
    By Torael_7 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2008, 12:58
  4. RC Oscillator
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2007, 19:27
  5. Holidays Allowed Here ???
    By Acetronics2 in forum Forum Requests
    Last Post: - 21st September 2006, 18:57
