Port alias in Port Expanders (MCP23S17)
Results 1 to 19 of 19
    Sep 2007
    Waco, Texas
    Default Re: Port alias in Port Expanders (MCP23S17)
    Richard-
    I tried the following:
                          OutA=$FFFF                                        'Initial value for word var
                          PortDevice=$D                                     'Var from comm link
                          K=PortDevice                                      'Copes var to var for hex to dec converter
                          gosub H2D                                         'Perform sub
                          OutA.K=0     'PBP3 barks with 'Bad variable modifier
                          OutA.0=0                                          'Bit mod - WORKS
                          OutA.2=0                                          'Another bit mod - WORKS                      OutA.0=0                                       'Bit mod - WORKS
                          OutA.8=0                                          'Another bit mod - WORKS
                          OutA.10=0                                         'Bit mod - WORKS
                          OutA.12=0                                         'Another bit mod - WORKS
                          OutA_hi=OutA.highbyte                             'Splits into hibyte
                          OutA_lo=OutA.lowbyte                              'And into low byte of the word var
                            OutA_MCPReg = OLATA                             'Sets up PORTA output
                            OutA_DataOut=OutA_lo                            'Sets up data to be pushed to the MCP23S17 as the low byte
                            gosub SEND_OutA_2317                            'Send it
                            pause 10                                        'Wait a bit
                            OutA_MCPReg = OLATB                             'Sets up PORTB output
                            OutA_DataOut=OutA_hi                            'Sets up data to be pushed to the MCP23S17 as the hi byte
    In an effort to get from the single byte to the pointer, but PBP3 barks with the bad variable modifier.......
    There a ought to be a way to do this.......
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Sep 2007
    Waco, Texas
    OK, it is working!
    Thanks to all who helped and provided some food for thought.....
    Code below for any others who need to do this:
                          OutA=$FFFF                                        'Initial value for word var - everything is OFF
                          PortDevice=$A                                     'Var from comm link
                          OutA.0[PortDevice]=0                              'This works!
    '                      OutA.2=0                                          'Manual bit mod - works though
    '                      OutA.12=0                                         'Manual bit mod - works though
    Happy New Year!
    -Steve
    - Albert Einstein
    OutA var word
    asm
    OutA_hi=OutA
    OutA_lo=OutA+1
    endasm
    OutA_hi var byte EXT
    OutA_lo var byte EXT
    the easy way
    ps I hope I got the endianness correct if not swap the hi byte low byte definitions
    yep I did get it wrong (choice of two I will pick the wrong one every time)
    found my endianness note
    MyVar =$AABB would be stored little-endian. I.E. if the address
    of MyVar starts at 30h, then $BB will be stored at 30h followed by $AA at 31h
    so
    asm
    OutA_hi=OutA+1
    OutA_lo=OutA
    endasm
    Sep 2007
    Waco, Texas
    Thanks, I will give that a try.
    Now if I could write both bytes at the same SPI communication, that would be an even bigger win!
    - Albert Einstein
    Aug 2011
    If you have the MCP23S17 IOCON register set to it's default setting of $00 that sets the chip to 16-bit mode (BANK=0) with auto address increment enabled (SEQOP=0).
    In that mode you can send register address byte = $14 (OLATA) and then write the two data bytes and they'll go to OLATA and OLATB.
    Sep 2007
    Waco, Texas
    That is exactly what I was looking for!
    I thought I had done this before but could have been mistaken.
    Will try later this evening.
    Thanks!
    -Steve
    - Albert Einstein
  1. I2C question w/ MCP23017 Port Expanders
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 26th December 2012, 06:47
  2. 18F2520 - problem configuring fuse for port B as digital port.
    By hwhisperer in forum mel PIC BASIC Pro
    Last Post: - 11th October 2010, 12:41
  3. LCD R/S works on Port A but not Port B
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 13:41
  4. RB port sequencer
    By freelancebee in forum mel PIC BASIC
    Last Post: - 17th August 2005, 20:58
  5. Duplicating port input to port output
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 22:43
