Here's what had worked for me. Richard is right, you cant use HPWM for frequencies above 32.768khz.
Set the registers as follows.
TRISC.2 = 0 ' CCP1 (PortC.2 = Output)
PR2 = 25 ' Set PWM Period for approximately 38KHz
CCPR1L = 13 ' Set PWM Duty-Cycle to 50%
CCP1CON = %00001100 ' Mode select = PWM
T2CON = %00000100 ' Timer2 ON + 1:1 prescale
This would give you a continuous 38khz on the pwm pin, at 50% duty cycle.
Now, toggle TRISC.2 between an input and an output at 1ms.
Hope it works! If it does, thanks go to Bruce Reynolds. If doesnt, brickbats to me!
Regards.
