Cooking (kitchen) Timer - Xtal or Resonator both too "slow"
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default OSCTUNE register
    ...well, I just tried to roughly adjust the oscillator's settings via the OSCTUNE register and it looks to make some effect.
    Until now, I was assuming OSCTUNE was only effective while using the internal oscillator.
    Am I wrong?
    Roger
    Default Re: OSCTUNE register
    No, something else is affecting the oscillator's accuracy. But what is it?
    I can't see "real" changes by setting the OSCTUNE register. Still believe it doesn't work when using an external oscillator.
    Roger
    On Interrupt Goto TICK_INT
    How many times an Hour ???
    BTW ... THIS
    CalibrationLoop:
     LCDOut $FE,$8B
     If TMR1Cal=0 then
     LCDOut " "
     If TMR1CalAR=0 then
     LCDOut "+"
     LCDOut "-"
     LCDOut #TMR1Cal," "
     ' Press Start Button to ADVANCE (speed-up) Clock
     ' Press STOP Button to RETARD (slow-down) Clock
     ' Press RESET Button to SAVE new Calibration Setting
     ' Remember each Calibration 'tick' will advance or
     ' retard the Timing by 1uS in every 10mS period - that's
     ' 360mS/Hour per setting. Example: A setting of +8 will
     ' SPEED-UP the Timer by 2.88 Seconds (8 x 360mS) in an Hour.
     If TMR1CalAR=0 then
     If ButStart=0 then Gosub CalAdvance
     If ButStop=0 then Gosub CalRetard
     If ButStart=0 then Gosub CalRetard
     If ButStop=0 then Gosub CalAdvance
     If ButReset=0 then
     Write 0,TMR1CalAR
     Write 1,TMR1Cal
     LCDOut $FE,1,"Have a Nice Day"
     Pause 1000
     Goto DisplayReset
     SetupTimeout=SetupTimeout+1
     If SetupTimeout>200 then goto DisplayReset
     Pause 100
     Goto CalibrationLoop
    has mysteriously disappeared from your code ...
    Wow, good notice about the calibration code! ;-)
    Going back to my desk and count the ticks in one hour...
    Merci Alain
    Roger
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Problems with my "intelligent timer"
    Last Post: - 21st September 2012, 19:06
  3. Replies: 0
    Last Post: - 21st April 2012, 16:29
  4. Alarms with Mel's "Olympic Timer" based timer - how to?
    Last Post: - 20th June 2007, 22:09
  5. Simple "backround" timer
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 05:11
