Cooking (kitchen) Timer - Xtal or Resonator both too "slow"
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default Cooking (kitchen) Timer - Xtal or Resonator both too "slow"
    Hi All,
    I've finished a cooking-timer (or kitchen-timer, as you like...) program and circuit.
    I made two prototypes up to now; the first equipped with a Xtal and the second with a resonator.
    Unfortunately, both circuits are "slow" in timing. After 1 hour internet time reference, the timer has still 24 to 25 seconds to go before its countdown is finished.
    I changed Xtal and capacitors (15pF), tried a ceramic resonator but nothing does.
    BTW, my circuit is using Melanie NEWMAN's "Olympic Timer".
    How can I tune things without having to bit bang the timer interrupt routine?
    '*  Name    : CookingTimer_N-logic_reso_16F690.pbp
    '*  Author  : FLOTUL
    '*  Notice  : Copyright (c) 2015 Flotulopex & Co.
    '*          : All Rights Reserved
    '*  Date    : 22.11.2015
    '*  Version : 2.0
    '*  Notes   :
    ' For use with 8MHz resonator and EAGLE board *reso*
    ' DESCRIPTION - Cooking (kitchen) Timer VERSION 2 (countdown) program using TMR0 Interrupt
    ' - ELECTRONIC ASSEMBLY DOGM081 (1x8) LCD display
    ' - TWO buttons ONLY
    ' - Each buttons's incremental time is programmable from 1' to 9'
    ' - Timer from 1 to 255 minutes (4 hours 15 minutes)
    ' - Buttons are Power-ON Soft-Switches
    ' - Buttons are not logic inverted because of "soft-switch" function (=> ON = 1, OFF = 0)
    ' - After two seconds no-press, countdown starts
    ' - Any press pauses countdown; any press resumes countdown
    ' - Any press stops alarm
    ' - 4kHz Piezo sounder steered by PWM /(Half-Bridge P1A & P1B)
    ' - Circuit does switch-OFF automatically after 255 seconds by alarm or 10 seconds in idle mode
    ' - Battery level is checked evey 10 seconds
    ' - Program hierarchy is special to quickly capture the switch-ON button
    ' - Circuit consumes 3,15mA (0,2mA for ADC)
    ' USAGE
    ' - To start timer, press either button to increment time; after 2 seconds no press, countdown starts.
    ' - Pressing buttons simultaneously any time will RESET the timer.
    ' - Keeping both button pressed (=RESET!) over 5 seconds will allow to toggle display "00:00" to "00m00s"
    ' - While incrementing time, keeping a button pressed for more than 5 seconds will
    '     initate the button's incremental time programming mode.
    ' - Any press stops alarm.
    ' - When timer is running, any button will pause countdown; press again to resume.
    ' - While "paused", sounder bips every 5 seconds.
    ' OPTION_REG & INTCON TMR0 settings
    ' OSC set to 8MHz : 4(operations per cycle) = 2'000'000 cycles per second
    ' Cycle duration is: 1s(second) / 2'000'000 = 0,5µs
    ' TMR0 increments from 0 to 255 = 256 steps
    ' Choosen TMR0 prescaler rate = 1:128
    ' One Tick (interrupt) happens every: 256 x 128 x 0,5µs = 16'384µs = 16,384ms
    ' So, in one second, there are: 1'000ms / 16,384ms = 61 Ticks
    'Identify HW-SW
    data 48,48,50,48   '0,0,2,0
    'Filename
    DATA @8,67,111,111,107,105,110,103,84,105,109,101,114,95,78,45,108,111,103,105,99,95,114,101,115,111,95,49,54,70,54,57,48
    ' Set inital values for buttons and display format
    DATA @5,1,5,0
    'Version history
    '0-0-2-0:
    ' PIC 16F690 Fuses (MPASM)
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_XT_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    '_INTRC_OSC_NOCLKOUT
    ' Registers   76543210
    OPTION_REG = %10000110 ' Pull-Ups OFF, Prescaler TMR0 1:128
    ANSEL      = %00000000 ' Select analog inputs Channels 0 to 7
    ANSELH     = %00000000 ' Select analog inputs Channels 8 to 11
    WPUA       = %00000000 ' Select weak pull-ups
    WPUB       = %00000000 ' Select weak pull-ups
    ADCON0     = %10110101 ' Select the VP6 channel as ADC input bits5:2 (xx1101xx)
    ADCON1     = %00110000 ' Set FRC
    VRCON      = %00010000 ' Enable the VP6 reference
    CM1CON0    = %00000000 ' Comparator1 Module
    CM2CON0    = %00000000 ' Comparator2 Module
    INTCON     = %10100000 ' INTerrupts CONtrol; GIE=1, T0IE=1
    TRISA      = %00000000 ' Select Input/Output (0 to 5)
    PORTA      = %00000100 ' Set High/Low (0 to 5)
    TRISB      = %00000000 ' Select Input/Output (4 to 7)
    PORTB      = %00000000 ' Set High/Low (4 to 7)
    TRISC      = %00000011 ' Select Input/Output (0 to 7)
    PORTC      = %00000000 ' Set High/Low (0 to 7)
    ' HPWM registers
    T2CON      = %00000101 ' Timer2 = ON (bit2), prescaler (bits1:0) 00=1, 01=4, 1x=16
    CCP1CON    = %00000000 ' Select PWM Mode (%00001100 = PWM module ON)
    CCPR1L     = 62        ' Dutycycle = proportional to PR2 (here = 50%)
    PR2        = 124       ' Freq 4kHz (specific to used piezo sounder)
    ' Defines
    define OSC 8
    DEFINE ADC_BITS 10     'Number of bits in ADCIN result
    ' Variables
    ' Declare minimum var to speed-up switch-ON process
    Btn1Val     var BYTE
    Btn2Val     var BYTE
    Dsp_Format  var bit     ' Display format: 0 = "00:00", 1 = "00m00s"
    READ 5,Btn1Val,Btn2Val,Dsp_Format
    Minutes     var byte
    minutes     = 0
    Btn1 var PORTC.1
    Btn2 var PORTC.0
    IF Btn1 = 1 then Minutes = Btn1Val
    IF Btn2 = 1 then Minutes = Btn2Val
    while Btn1 = 1 : WEND
    while Btn2 = 1 : WEND
    ' Declare vars normally from here
    Alarm       var bit
    Alarm       = 0
    Bat_Level   var byte    ' for LCD character selection (3:7)
    Bat_Level   = 7
    Bat_Value   var word    ' holds ADC value
    Bat_Value   = 0
    Cnt_A       var word
    Cnt_a       = 0
    DataPin     var PORTA.0 ' for DEBUG - serial data OUT
    Dsp_Upd     var bit     ' Display Update Allowance
    DSP_Upd     = 1
    IdleCounter var byte    ' counter that increments while timer is 00:00
    IdleCounter = 0
    Mode        Var word    ' for DEBUG
    Mode        = 32        ' PICKit DTN 84=9600,32=19200 : SerialCom DIN 16468=9600,16416=19200
    Paused      var bit
    paused      = 0
    Run         var bit     ' timer's running flag
    RUN         = 0
    Seconds     var byte
    Seconds     = 0
    SoftSwitch  var PORTA.2
    SoftSwitch  = 1
    StatusSym   var byte    ' shows alarm or pause symbol on LCD
    StatusSym   = " "
    Ticks       var byte
    Ticks       = 0
    ' Init display
    DEFINE LCD_DREG PORTB  ' LCD data port
    DEFINE LCD_DBIT 4      ' LCD data starting PORT.bit (0 or 4)
    DEFINE LCD_RSREG PORTC ' LCD register select port
    DEFINE LCD_RSBIT 7     ' LCD register select bit
    DEFINE LCD_EREG PORTC  ' LCD enable port
    DEFINE LCD_EBIT 6      ' LCD enable bit
    DEFINE LCD_BITS 4      ' LCD bus size 4 or 8
    ' ELECTRONIC ASSEMBLY DOGM081 LCD display Mandatory settings
    '  See datasheet for circuitry changes by 5V or 3,3V operation
    pause 100              ' Time to settle Vdd, normally 1000ms (THIS IS CRUCIAL!!!)
    lcdout $FE, $29        ' Function Set: 4 bits bus mode
    lcdout $FE, $1C        ' Bias set
    lcdout $FE, $52        ' Power control + Contrast (HiByte)(for 5V=$52 or 3,3V=55)
    lcdout $FE, $69        ' Follower control (5V=$69/3,3V=6D)
    Lcdout $FE, $75        ' Contrast (LowByte)
    ' Custom Characters
    lcdout $FE,$28 'Function Set change - ONLY valid for ST7036 controller based LCDs
        LCDOUT $FE,$40,$02,$06,$1A,$1A,$1A,$06,$02,$00 'Char 0 = Speaker
        'LCDOUT $FE,$48,$00,$08,$0C,$0E,$0C,$08,$00,$00 'Char 1 = Run symbol
        LCDOUT $FE,$50,$00,00,$1B,$1B,$1B,$1B,$00,$00 ' Char 2 = pause symbol
        LCDOUT $FE,$58,$00,$1F,$11,$11,$11,$1F,$00,$00 ' Char 3 = big square
        LCDOUT $FE,$60,$00,$00,$0E,$0A,$0E,$00,$00,$00 ' Char 4 = small square
        LCDOUT $FE,$68,14,27,17,17,31,31,31,00 'Char 5 = Battery 3/5 full
        LCDOUT $FE,$70,$04,$04,$04,$04,$04,$1F,$0E,$04 ' Char 6 = Down arrow
        LCDOUT $FE,$78,14,31,31,31,31,31,31,00 'Char 7 = Battery 5/5 full
    lcdout $FE,$29 'Function Set change
    ' Start program
    On Interrupt Goto TICK_INT
    MAIN:
    if RUN = 0 then ' Timer is stopped (idle)
    ' Add minutes to timer
        IF Alarm = 0 THEN
            StatusSym = " "
    ' Switch PWM OFF and pull piezo's ports down
            GOSUB SOUNDER_OFF
    ' Add Btn1 minutes and allow RESET if both buttons are pressed simultaneously
            If Btn1 = 1 Then
                Minutes = minutes + Btn1Val
                GOSUB UPDATE_DISPLAY
                IdleCounter = 0
                Ticks       = 0
                WHILE Btn1 = 1
                    if IdleCounter > 4 then ' after 3 secs, goto set btn value
                        Btn1Val = Btn1Val - 1
                        if Btn1Val < 1 then Btn1Val = 9
                        while Btn1 = 1 ' increment btn value as long as btn is pressed
                            Btn1Val = Btn1Val + 1
                            if Btn1Val > 9 then Btn1Val = 1
                            Lcdout $FE,2,4," Time:", dec1 Btn1Val
                        WEND
                        write 5, Btn1Val
                        idlecounter = 0
                    IF Btn2 = 1 then GOSUB RESET
                WEND ' does also act as debounce
    ' Add Btn2 minutes and allow RESET if both buttons are pressed simultaneously
            If Btn2 = 1 Then
                MINUTEs = MINUTEs + Btn2Val
                IdleCounter = 0
                Ticks       = 0
                WHILE Btn2 = 1
                    if IdleCounter > 4 then ' after 5 secs, goto set btn value
                        Btn2Val = Btn2Val - 1
                        if Btn2Val < 1 then Btn2Val = 9
                        while Btn2 = 1 ' increment btn value as long as btn is pressed
                            Btn2Val = Btn2Val + 1
                            if Btn2Val > 9 then Btn2Val = 1
                            Lcdout $FE,2,3," Time:", dec1 Btn2Val
                        WEND
                        write 6, Btn2Val
                        idlecounter = 0
                    IF Btn1 = 1 then GOSUB RESET
    ' Switch-OFF circuit after 10 seconds
            IF IdleCounter > 9 then   '**** = 5
                alarm      = 0
                SoftSwitch = 0
    ' Start the countdown timer after 2 seconds no press (=> RUN = 1)
            if minutes > 0 THEN
                if IdleCounter > 0 then
                    if Ticks = 60 then ' allow change until last moment before start
                        RUN     = 1
                        Alarm   = 0
        endif ' Alarm = 0
        if Alarm = 1 THEN
            StatusSym = 0
    ' Stop alarm by any button press
            while Btn1 = 1
                idlecounter = 0
                Alarm = 0
            WEND
            WHILE Btn2 = 1
                idlecounter = 0
                Alarm = 0
            WEND
    ' Switch-OFF circuit after 255 seconds by alarm
            IF IdleCounter = 255 then
                alarm      = 0
                SoftSwitch = 0
    ' Alarm - Piezo sounder activation (PWM)
            IF idlecounter // 2 = 0 then
                CCP1CON = %10001100 ' enable half-bridge PWM
                GOSUB SOUNDER_OFF
        endif ' Alarm = 1
    endif   ' RUN = 0
    IF RUN = 1 THEN ' Timer is running
    ' Countdown timer has ended = enable alarm
        if minutes = 0 THEN
            IF seconds      = 0 THEN
                RUN         = 0
                IdleCounter = 0
                Alarm       = 1
                StatusSym   = 0
    ' Stop and GO! ("Paused") Allow to stop countdown and resume
        IF paused = 0 then
            StatusSym = " "
    ' Activate "Paused" mode or RESET
            IF Btn1 = 1 THEN
                PAused      = 1
                IdleCounter = 1
                Dsp_Upd     = 1
                WHILE Btn1 = 1
                WEND
            IF Btn2 = 1 THEN
                PAused      = 1
                IdleCounter = 1
                Dsp_Upd     = 1
                WHILE Btn2 = 1
                WEND
        endif ' "Paused = 0"
        IF Paused = 1 then
            StatusSym = 2 ' pause symbol
            IF idlecounter // 5 = 0 then
                GOSUB SOUNDER_OFF
    ' Deactivate "Paused" mode or RESET
            IF Btn1 = 1 THEN
                PAused = 0
                GOSUB SOUNDER_OFF
                IdleCounter = 1
                Dsp_Upd = 1
                WHILE Btn1 = 1
                WEND
            IF Btn2 = 1 THEN
                PAused = 0
                GOSUB SOUNDER_OFF
                IdleCounter = 1
                Dsp_Upd = 1
                WHILE Btn2 = 1
                WEND
        ENDIF ' "Paused = 1"
    ENDIF ' "RUN = 1"
    ' Battery check every 10 seconds
    IF idlecounter // 10 = 0 then gosub BATTERY_CHECK
    ' Update display each second
    if Dsp_Upd = 1 then GOSUB UPDATE_DISPLAY
    GOTO MAIN
    ' SUBROUTINES
    RESET:
        Lcdout $FE,2," Reset! "
        RUN         = 0
        Alarm       = 0
        StatusSym   = " "
        Minutes     = 0
        Paused      = 0
        seconds     = 0
        IdleCounter = 0
        CCP1CON     = %00000000
        PORTC.4     = 0
        PORTC.5     = 0
        Dsp_Upd     = 1
        WHILE Btn1 = 1
            IF Btn2 = 1 then
                IF IdleCounter > 4 then '..if both buttons are still pressed after 5 seconds then
                    IF Dsp_format = 1 then
                        Dsp_format = 0
                        Lcdout $FE,2, "   00:00"
                        pause 2000
                        goto LEAVE2
                    IF Dsp_format = 0 then
                        Dsp_format = 1
                        Lcdout $FE,2, "  00m00s"
                        pause 2000
                        GOTO LEAVE2
                LEAVE2:
                write 7, dsp_format
        WEND
        IdleCounter = 0
        PAUSE 300
    SOUNDER_OFF:
        CCP1CON = %00000000
        PORTC.4 = 0 ' pull port down because piezo doesn't like DC
        PORTC.5 = 0 '   "    "    "     "       "     "      "   "
    UPDATE_DISPLAY:
    ' Update display every elapsed second and adapt (# of "Minutes" digits) display
        Dsp_Upd = 0
        if minutes > 99 then
            if dsp_format = 0 then
                Lcdout $FE,2,"  ",  dec3 minutes,":",dec2 Seconds
                Lcdout $FE,2," ", dec3 minutes,"m",dec2 Seconds,"s"
            'Serout2 DataPin,Mode,[dec1 minutes,"m ",dec2 Seconds,"s",13,10]
            GOTO LEAVE1
        if minutes >  9 then
                Lcdout $FE,2,"   ", dec2 minutes,":",dec2 Seconds
                Lcdout $FE,2,"  ", dec2 minutes,"m",dec2 Seconds,"s"
            GOTO LEAVE1
        if minutes >= 0 then
                Lcdout $FE,2,"    ",dec1 minutes,":",dec2 Seconds
                Lcdout $FE,2,"   ", dec1 minutes,"m",dec2 Seconds,"s"
        LEAVE1:
        ' Alarm symbol blinker
            Lcdout $FE,$80,StatusSym
            Lcdout $FE,$80," "
    ' Check battery level using PIC's internal 0,6V reference
    '  Battery monitoring system according to MICROCHIP's AN1072
    BATTERY_CHECK:
        disable
        ' Following 3 registers set on top of program - only here as reminder - DO NOT UNCOMMENT
        'ADCON0 = %10110101 ' Select the VP6 channel (13) to select 0,6V reference
        'ADCON1 = %00110000 ' Set FRC (Frequency)
        'VRCON  = %00010000 ' Enable the VP6 reference
        ADCON0.1 = 1        ' Start ADC
        while ADCON0.1 : wend
        Bat_Value.HighByte = ADRESH : Bat_Value.LOWByte = ADRESL
        IF Bat_Value >= 120 then Bat_Level = 5
        IF Bat_Value <  119 then Bat_Level = 7
        resume
        enable
    ' Interrupt routine to handle each timer tick
    disable
    TICK_INT:
        Ticks = Ticks + 1        'Count pieces of seconds
        If Ticks < 61 Then TICK_FLAG_RESET  '61 ticks per second (16.384ms per tick)
        ' One second has elasped
        Ticks = 0
        IdleCounter = IdleCounter + 1
        Dsp_Upd = 1 'one second has elapsed, update is allowed
        IF RUN = 1 THEN
            if paused = 0 then
                Seconds = Seconds - 1
                If Seconds = 255 then  '= Second is "smaller" than 0
                    seconds = 59
                    minutes = minutes -1
                Endif
        TICK_FLAG_RESET:
        INTCON.2 = 0  'reset T0IF flag
        Resume
    enable
    ' [PIC] - (LCD) EA-8081-A3N 4-bits circuitry
    ' (LCD) EA DOG-Mxxx-A 4-bits circuitry
    '(27,38) Vss - GND
    '(23,24,26,27,32,33,32,35,40) Vdd / Vcc +5V or 3,3V
    '(38) LCD-R/W -> to Vss
    '      [PIC] (LCD)
    'PORTA.0[19] ICSPDAT
    'PORTA.1[18] ICSPCLK
    'PORTA.2[17] Soft-Switch
    'PORTA.3[04] MCLR
    'PORTA.4[03] OSC2 - Xtal
    'PORTA.5[02] OSC1 - Xtal
    'PORTB.4[13] (31) LCD-D4
    'PORTB.5[12] (30) LCD-D5
    'PORTB.6[11] (29) LCD-D6
    'PORTB.7[10] (28) LCD-D7
    'PORTC.0[16] R Button
    'PORTC.1[15] L Button
    'PORTC.2[14]
    'PORTC.3[07]
    'PORTC.4[06] CCP1/PWM piezo sounder on P1B
    'PORTC.5[05] CCP1/PWM piezo sounder on P1A
    'PORTC.6[08] (36) LCD-E
    'PORTC.7[09] (39) LCD-RS
    Roger
    Default OSCTUNE register
    ...well, I just tried to roughly adjust the oscillator's settings via the OSCTUNE register and it looks to make some effect.
    Until now, I was assuming OSCTUNE was only effective while using the internal oscillator.
    Am I wrong?
    Roger
    Default Re: OSCTUNE register
    No, something else is affecting the oscillator's accuracy. But what is it?
    I can't see "real" changes by setting the OSCTUNE register. Still believe it doesn't work when using an external oscillator.
    Roger
    How many times an Hour ???
    BTW ... THIS
    CalibrationLoop:
     LCDOut $FE,$8B
     If TMR1Cal=0 then
     LCDOut " "
     If TMR1CalAR=0 then
     LCDOut "+"
     LCDOut "-"
     LCDOut #TMR1Cal," "
     ' Press Start Button to ADVANCE (speed-up) Clock
     ' Press STOP Button to RETARD (slow-down) Clock
     ' Press RESET Button to SAVE new Calibration Setting
     ' Remember each Calibration 'tick' will advance or
     ' retard the Timing by 1uS in every 10mS period - that's
     ' 360mS/Hour per setting. Example: A setting of +8 will
     ' SPEED-UP the Timer by 2.88 Seconds (8 x 360mS) in an Hour.
     If TMR1CalAR=0 then
     If ButStart=0 then Gosub CalAdvance
     If ButStop=0 then Gosub CalRetard
     If ButStart=0 then Gosub CalRetard
     If ButStop=0 then Gosub CalAdvance
     If ButReset=0 then
     Write 0,TMR1CalAR
     Write 1,TMR1Cal
     LCDOut $FE,1,"Have a Nice Day"
     Pause 1000
     Goto DisplayReset
     SetupTimeout=SetupTimeout+1
     If SetupTimeout>200 then goto DisplayReset
     Pause 100
     Goto CalibrationLoop
    has mysteriously disappeared from your code ...
    Wow, good notice about the calibration code! ;-)
    Going back to my desk and count the ticks in one hour...
    Merci Alain
    Roger
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Problems with my "intelligent timer"
    Last Post: - 21st September 2012, 19:06
  3. Replies: 0
    Last Post: - 21st April 2012, 16:29
  4. Alarms with Mel's "Olympic Timer" based timer - how to?
    Last Post: - 20th June 2007, 22:09
  5. Simple "backround" timer
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 05:11
