Hi guys, I'm running a DS1307 and have experienced some strange jumps in time that has been replicated by a friend using his own development board. When the system is first powered up the clock displays the default time of 14:00, and runs ok until 15:59. When it rolls over to 16:00 it actually jumps to 08:00 and then continues to run Ok displaying 08:01, 08:02 etc. If after power up I set the time to 15:59 using the option in the menu it correctly displays 16:00 16:01 etc without issue. Equally, when it is powered up, displays 14:00 and trips to 08:00, if left to run on for 8 hours, it correctly displays 16:00 when the time has elapsed.
Here's are the time variables
And then I have this initial settingCode:;----[Variables/Aliases - Time]------------------------------------------ RTCSec var byte ' Seconds RTCMin var byte ' Minutes RTCHour var byte ' Hours RTCWDay var byte ' Weekday RTCDay var byte ' Day RTCMonth var byte ' Months RTCYear var byte ' Year RTCCtrl var byte ' Control SetTime var byte ' 12/24 Hour Clock SetSec var byte ' Seconds SetMin var byte ' Minutes SetHour var byte ' Hours TimeOut var word ' Variable for SetUp Menu Time-Out TimeH var byte ' Variable to store current hour for comparison to drop temp time TimeM var Byte ' Variable to store current minutes for comparison to drop temp time
And then this is the section in the main loop that reads the chip and displays the timeCode:RTCSec=0 RTCMin=0 RTCHour=14 I2CWrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
And finally here's the section that deals with manually setting the time from the menuCode:I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl] ; read DS1307 chip If RTCHour.6=1 then CounterA=(RTCHour>>4)&$01 ' Work-Out 12 or 24 hour Display for Hours else CounterA=(RTCHour>>4)&$03 endif CounterA=CounterA*10+(RTCHour&$0F) ' Display Hours appropriately for 12 or 24 hour Mode If RTCHour.6=1 then LCDOut $FE,$c0+11,#CounterA else LCDOut $FE,$c0+11,#CounterA Dig 1,#CounterA Dig 0 endif LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F timeH=(RTCHour>>4) 'convert the BCD format of the hours register and store in variable timeH timeH=(timeH &$03)*10 timeH=timeH+(RTCHour&$0F) timeM=(RTCMin>>4) timeM=(timeM &$07)*10 timeM=timeM+(RTCMin&$0F) 'convert the BCD format of the mins register and store in variable timeM
I'm at a loss ? - any suggestionsCode:time: LCDOUT $FE,1 LCDOUT $FE,2,"Set Time" inp3: IF H_butt = 0 THEN GOSUB IncHours IF M_butt = 0 THEN GOSUB IncMinutes SetHour=Hours SetMin=Minutes LCDOUT $FE,$C0,#SetHour DIG 1,#SetHour DIG 0,":",#SetMin DIG 1,#SetMin DIG 0 pause 200 If S_butt = 0 then pause 250 goto savetime endif goto inp3 savetime: ' Save 12/24 Hours to BCD DS1307's Format ' --------------------------------------- CounterA=SetHour If SetTime=1 then If CounterA>12 then CounterA=CounterA-12 If CounterA=0 then CounterA=12 endif Gosub ConvertBCD RTCHour=CounterB ' Save the Hours Value If SetTime=1 then RTCHour.6=1 ' Save the 12 Hour Mode Flag If SetHour=>12 then RTCHour.5=1 ' Save the 'PM' Flag endif ' ' Save Minutes ' ------------ CounterA=SetMin Gosub ConvertBCD RTCMin=CounterB CounterA=SetSec Gosub ConvertBCD RTCSec=CounterB I2CWrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl] goto mainmenu
