Avoid HSEROUT command?
Results 1 to 9 of 9
    Exclamation Avoid HSEROUT command?
    I'm using a PIC18F2331 running at 40MHz and my program is quite heavy, the µC got a lot of work to do with a lot of interrupts.
    I usually use the HSEROUT command for sending 8 variables to my PC via UART, like this :
    hserout[a,b,c,d,e,f,i,j]
    (values from a to j are bytes)
    But I noticied that this command is very time-consuming in my program, and it disturbs some of my high-frequency interrupts.
    So I'm considering to NOT use that HSEROUT command, but manually fill the TXREG buffer :
    If PIR1.4 = 1 Then
       TXREG = a              ' Send character to transmit register
    But how I can send all my byte-sized variables (a,b,c,d,e,f,i,j) at the same time with this method?
    Default Re: Avoid HSEROUT command?
    As long as the HSEROUT statement itself isn't IN an interrupt routine I don't see HOW it can disturb any interrups (as long as you're not using ON INTERRUPT of course but I suspect you're NOT).
    But to answer your question, if you can put all your variables after each other, ie in an array, then a simple FOR-LOOP will do but really, I don't see it being any better than HSEROUT but man have I been wrong before :-)
    Hi Henrik,
    I use the DT instant interrupts, i've one main loop, one high-speed high priority interrupt (running at 13kHz and doing some calculations) and one low-priority interrupt (running at 100Hz).
    The HSEROUT command is in the main loop.
    But still, when it sends data at a high rate, the low-priority interrupt is disturbed. I'm running at 2400bps.
    Aug 2003
    You’re not taking advantage of hardware serial at all unless you send a byte at a time.
    Otherwise it’s blocking just like software serial. A for next loop sending hardware serial will also block just the same.
    atoj var byte[8]
    index var byte
    serbuff var byte
    to send continuously:
    mainloop:
    ‘ your program
    if index > 7 then
    index = 0’
    if index < 8 then
    serbuff = atoj[index]
    hserout[serbuff]
    index = index + 1
    goto mainloop
    Don’t write into the buffer while index is less than 8.
    I'm with henrik on this
    As long as the HSEROUT statement itself isn't IN an interrupt routine I don't see HOW it can disturb any interrupts
    if you were to use an interrupt routine to output for your 8 bytes of data then that would impact on your other interrupts , pbp style irqs done with dt_ints have some pretty heavy overheads
    when art says
    that's not strictly correct , hserout is interruptible using dt_ints
    Aug 2003
    Don’t know why it would interfere with an interrupt, but I mean this
    led off
    led on
    is no better than doing the same thing with software serial.
    The led won’t turn on until all eight bytes are sent.
    led off
    hserout[byte]
    led no
    Where as the above doesn’t even have to wait for the single byte to send serially.
    If you were going to interrupt this:
    sendingserial = 1
    sendingserial = 0
    You’d have to be sure your interrupt doesn’t change any vars a-j while sendingserial = 1 or you’d end up
    with a composite of what was supposed to be two commands (i.e. you don’t know where it’s up to).
    led off
    led on
    led off
    hserout[byte]
    led no
    sendingserial = 1
    sendingserial = 0
    You say that I should use a low priority interrupt for sending all my bytes?
    Aug 2003
    I don’t know if you are sending serial in the interrupt or main program, and assumed it’s in the main program.
    Having said that, I can’t think of a reason you need to do serial in the interrupt, but there might be a reason.
    I’m saying sending a slab like that will ruin the illusion of doing things simultaneously like programs do,
    and that there’s no recovering from it.
    Think if you did this:
    Then later you wanted the same program to also receive a serial command that could arrive at any time. You’re screwed.
    For example if a GPS sent it’s data sentence to your chip while in the middle of your program sending that eight byte slab.
    But you can easily have a fully duplex serial port with PBP HSEROUT.
    You can be sending the eight byte slab at the same time as receiving something,
    and once implemented you barely have to think about it.
    atoj var byte[8]
    rxbuffer[8]
    index var byte
    rxindex var byte
    serbuff var byte
    rxbuff var byte
    mainloop:
    ‘ your program
    if index > 7 then ‘ data packet was sent, so send another.
    index = 0’
    if rxbuff = enterkey then ‘ check for end of incoming command
    rxindex = 0
    ‘do something with received command
    if index < 8 then
    hserout[serbuff]
    index = index + 1
    if rxindex < 8 then
    hserin[rxbuff,shortesttimeout,donelabel]
    donelabel:
    rxbuffer[rxindex] = rxbuff
    rxindex = rxindex + 1
    goto mainloop
    atoj var byte[8]
    rxbuffer[8]
    index var byte
    rxindex var byte
    serbuff var byte
    rxbuff var byte
    mainloop:
    ‘ your program
    index = 0’
    rxindex = 0
    if index < 8 then
    hserout[serbuff]
    index = index + 1
    if rxindex < 8 then
    donelabel:
    goto mainloop
    Thanks Art, it works quite well
    I've no more latency done by the HSEROUT command.
    Thanks!
  1. ADCIN & 16F870 - how to avoid non linear conversion?
    Last Post: - 21st March 2014, 09:02
  2. How can I avoid stack corruption
    Last Post: - 30th August 2013, 03:45
  3. How to avoid DIV32 command?
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 16th May 2011, 07:11
  4. How to avoid corrupting an EEPROM Write
    Last Post: - 6th July 2005, 09:34
  5. 16F877 and Hserout command
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 29th May 2004, 11:30
